Glossary
Last Update:Aug 19 2025 1:54am • Est. Read Time:Est. Read Time: 7 MINHave you ever run into any words on the Rachio app that you don't know the meaning of? This article will list some really useful terms that you might don't know yet!
App
The Rachio application is available for free on Android's Play Store and Apple's App Store. It is also available with limited functionality online at https://app.rach.io/
Rachio App Home Screen
How do I update my Rachio app?
Rachio Mobile App Changelog (iOS)
Rachio Mobile App Changelog (Android)
Where can I download the Rachio App?
What's new with the Rachio app?
How do I find Multiple Controllers? (Device Lookup)
Advanced Wiring
Master Valves or Pump Start Relays are attached to the "M" Terminal on the controller. In order for these tools to work properly, we have to set them correctly on the Rachio app.
Do I have Advanced Wiring (Generation 2)?
Wiring your Controller
Wiring Label (Generation 1)
How do I Wire one Master Valve, pump, or common wire to two controllers?
What should I do if my wires don't fit?
Water Pumps & Relays
Allowed Depletion
The maximum amount of water (moisture) that can evaporate from your zones before a watering cycle occurs.
Available Water
The amount of available water that can be stored in the soil in that zone.
Band
The range of radiofrequency used to transmit information through the Wi-Fi Network. It could be a 2.4 GHz, 5 GHz, or merged system (which has both 2.4 GHz and 5 GHz integrated into a single wifi network). Mesh networks are the ones that contain several access points throughout the house.
BlinkUp
The process used to connect Generation 1 controllers to the Wi-Fi Network via its photosensor.
How do I BlinkUp my controller?
Check the Rachio Generation 1 Quick Start Guide here
Click here for Generation 1 Tech Specs
BlinkUp tips for Android phones
Calendar
The 'Calendar' tab on the app lets you view the scheduled watering times for the month.
Common Wire
Usually a white wire; runs through all the valves and goes back to the C Terminal on the controller, closing the circuit.
Check the Rachio Generation 2 Quick Start Guide here
Check the Rachio 3 Quick Start Guide here
How to replace your Rachio Generation 2 with a Rachio 3
Community
Join the Rachio Community! There, you'll interact with several Rachio users and also with the Rachio Team.
Crop Coefficient
Plants' properties; used in predicting evapotranspiration.
How does it affect Flex Daily Schedules?
Cycle and Soak
A method that prevents water runoff by breaking total watering times into smaller portions.
Smart Cycle and Manual Cycle and Soak.
Direct Access
Designed for Irrigation Technicians, this feature can be used to configure a new controller/schedule without Wi-Fi.
Direct Access for Rachio Professional Partners
Efficiency
How uniformly the sprinkler heads distribute water on the zone.
How do I perform an Irrigation Audit of my Sprinkler System?
Evapotranspiration
The amount of water a zone loses from plant transpiration and evaporation from the ground. One of the key parts of a Flex Daily Schedule.
Click here to see how it works.
Factory Reset
By factory resetting the controller, you clear any residual data preventing the controller from working properly. You do not lose settings such as zones and schedules.
How do I Factory Reset my controller?
Flex Monthly/Flex Daily
Dynamic schedules that change watering times/frequencies based on Soil Moisture (Daily) or Historical Data (Monthly).
How to set up a Flex Schedule?
How should I set up a Flex Monthly Schedule?
How do I edit intervals on Flex Monthly Schedules?
How do I edit the duration and frequency of a Flex Schedule?
Firmware
Low-level software that operates the controller or WFM’s Hardware.
How do I update my controller's firmware?
Fixed Schedule
The most predictable type of schedule, allows you to select when/how much to water each of your zones. It still works with the Weather Intelligence Features.
History Feed
Where you can see all the historical information on your Rachio system, including runs, updates, and changes.
IFTTT
"If This Then That" is a tool that lets you set triggers for automated actions for your Rachio Controller.
How do I use IFTTT with my Rachio?
Indexing Valve
A valve that uses time-based sequencing to distribute water through different zones
MAC Address
Media Access Control Address. This is the number that allows your controller to communicate with your Wi-Fi Network.
Master Valve: A valve installed upstream from the regular valves that control water flow into the main piping system.
Is there a maximum distance my valves can be from my Rachio controller?
Moisture Level
Shown in percentage, is the amount of available water that a specific zone has at the moment. An essential part of a Flex Daily Schedule.
Personal Weather Station
A domestic set of weather measuring equipment. It can be installed at your house.
Personal Weather Stations & Rachio
Connect Tempest Personal Weather System to Rachio Controller
Pump Start Relay
An electrical relay that starts the pump whenever the Rachio controller runs a zone.
Click here to check compatible Pump Start Relays.
How do I wire a pump to my Rachio Generation 1?
Delay Between Zones
Water Pumps & Pump Relays
Pressurize Time
The time it takes for your zones to reach fully pressurized flow; is when all heads or emitters put out water as designed.
Quick Run
Running a zone or schedule anytime you want, either from the controller or from the app.
How do I manually run one or more zones?
How do I turn on one zone?
Rain Sensor
In case of rain, a Rain Sensor attached to your Rachio controller will prevent any watering event.
Rain Sensors FAQ
Rain Skip
In case Weather Intelligence gathers a rain prediction from the Weather Station, the watering schedule will be skipped.
Rain Skip FAQ
Root Depth
The soil depth from which a plant extracts most of its water needs.
RSSI
Received Signal Strength Indication (in this case, the Wi-Fi Signal Strength by the Controller).
Saturation Skip
It determines if your yard has enough moisture to last until the next scheduled watering.
Seasonal Shift
This feature adjusts the watering times on a Schedule according to historical Weather data.
Schedule
Watering events that will automatically start according to your set preferences.
How do I create a watering schedule?
How do I edit a watering schedule?
Can I control my Rachio controller from anywhere?
What if my controller goes offline?
How do I know what schedules are running and when?
How do I run a zone manually (Rachio Generation 2)?
How do I run a zone manually (Rachio 3)?
Watering Times are too High/Low?
How many Schedules can I create?
Shared Access
This feature lets you share the access of your controller (your landscaper, for example) while still being the main owner.
How to Use Shared Access?
How to Use Complete Access?
Solenoid
An electrically controlled valve that regulates the flow of water from the system into the sprinklers.
Click here to check solenoid compatibility.
Hibernation (formerly Standby) Mode
Your controller is on hibernation. All scheduled watering will be skipped.
SSID
The name of a Wi-Fi Network.
Transfer Ownership
Transferring a controller from an account to another.
Moved into a house with a built-in Rachio 3?
How do I share my Controller with someone else?
Transfer ownership of a Rachio controller to your account
Water Usage
This section helps you keep track of the amount of water your sprinklers apply.
Water Usage and Water Savings
Water Hammer
A pressure surge or wave, caused when a fluid in motion is forced to stop suddenly, which can cause major problems to the sprinkler system. It is possible to reduce the effects of the water hammer pulses with Rachio's "Reduce Water Hammer" feature.
Different features that act as weather triggers to skip the watering schedule or adjust its duration.
What is Weather Intelligence Plus™?
Why doesn't the weather data match on my Rachio?
Weather Network
Instead of gathering information from a single Weather Station, Weather Intelligence Plus™ gather information from more than 270,000 personal weather networks, resulting in even more accurate results.
How do I select my preferred Weather Station?
How do I use Weather Underground with my Rachio?
What Weather Station are you using for my property?
Weatherproof Outdoor Enclosure
An enclosure that allows the controller to be installed outdoors. Can be hardwired.
Click here for the installation guide
Web App
Other than cell phones or tablets, you can use your computer internet browser to control your system at app.rach.io.
Wi-Fi Update
Whenever something changes to your Wi-Fi Network (name, password, router, etc.), we need to update the unit’s Wi-Fi connection.
How do I update the Wi-Fi on my controller (Generation 2, 3)?
How do I update the Wi-Fi on my controller (Generation 1)?
Basic Wi-Fi Tips and Troubleshooting.
Offline Troubleshooting Tips (Generation 1)
Wi-Fi Troubleshooting Self Help
What is Wi-Fi Assist? (Apple devices)
Rachio 3 Quadrant 2 Light Flashing Yellow
Rachio 3 Quadrant 3 Light Flashing
Rachio Generation 1 Light Codes
Amber Wi-Fi Light (Generation 1)
Rachio Generation 2 Light Codes
What does Light 1 mean? (Generation 2)
Light 1 Troubleshooting
What does Light 2 mean? (Generation 2)
What does Light 3 mean? (Generation 2)
What does Light 4 mean? (Generation 2)
Light/Quadrant 4 Rachio 3 and Generation 2
Wi-Fi Setup Tips for iOS (Generation 2)
Wi-Fi Setup Tips for Android (Generation 2)
Advanced Wi-Fi Troubleshooting
Winterize
To prevent the system from freezing and damaging the equipment, we need to prepare it for the winter.
How do I re-activate my system after the Winter?
Wireless Flow Meter
Measures how slowly (or quickly) the water is flowing through your system.
Wireless Flow Meter Tech Specs
Advanced Installation for the Wireless Flow Meter
Troubleshooting the Wireless Flow Meter
Installation Guide for the WFM - 1-inch PEX
Installation Guide for the WFM - 3/4-inch PEX
Notifications: Wireless Flow Meter and Wired Flow Meters
How do I install a wired sensor or wired flow meter with Rachio 3?
Zone
A specific area of your yard, which is activated by a single valve. Rachio controllers can control 4, 6, 8, 12, or 16 zones according to their version.
Can I add pictures to my zones?
Where can I find details about my zones?
What Soil Types are in the Rachio App?
Yard Map
What type of vegetation (Zone Type) do I have?
What do I need to know to set up my zones?
What's my level of sun exposure, or how much shade do I have?
What type of spray head or nozzle do I have?
How do I calculate my Precipitation Rate?
Why won't one zone turn on? (Generation 1)
Useful Links
Rachio Manuals and Resources
What can you do with your Rachio 3?
How do I change the e-mail address on my Rachio account?
Subscribe to Rachio Emails
Rachio Smart Home Integrations
