Generation 1 Tech Specs
Last Update:Jan 4 2023 5:24pm • Est. Read Time:Est. Read Time: 2 MINSummary
Are you questioning if your Generation 1 can connect to 5.8Ghz frequency? Or maybe, what are the power requirements for the controller? This article will help you with the technical specifications of your Generation 1 controller.
Rachio App Compatibility
Click here for Rachio App Compatibility Requirements.
Internet
This Rachio controller requires a 2.4ghz Wi-Fi internet connection (802.11 b/g/n).
Supported Wi-Fi encryption standards:
- WPA2 (recommended)
- WPA
Enterprise level encryption is NOT supported .
We recommend internet connections with a 1 mb or higher upload speed for optimal performance.
In the event of WiFi outage or interuptions, the controller’s memory retains the last saved schedule received from the Rachio cloud and maintains the schedule until an update can be downloaded. ( more info here )
Power
- Transformer Power Input: 120V AC / 60Hz
- Transformer Power Output: 24V AC (1000 mA = 1 Amp)
- Designed For 24V AC Solenoids
- Power Supply: External Transformer (6 ft cord)
- Power Supply Housing: 2-1/8" 3-1/8" x 1-3/4"
In the event of a power outage, the system will not run. Account, zone and schedule settings will be saved in the Rachio cloud.
Model Numbers
- 16 zones (16ZULW)
- 8 zones (8ZULW)
Languages (Rachio App)
- English
Size and weight
- Dimensions: 2.165” x 7.25” x 7.25”
- Weight: 2.7 Lbs
Environmental
- Indoor Installation ( Outdoor Installation with Enclosure )
- Temperature Range: -31F - 140F
Sprinkler Compatibility
- Zone Capacity
- 16 zones + Master Valve/Pump Relay ( Need to Run 16+ Zones? )
- Rain Sensor
- Wired & Wireless Normally Closed (NC) sensors
- Soil Sensor
- Flow Sensor
- Not supported on Generation 1 controllers
Warranty
In the box
- Rachio Controller (Wallmount + Front Panel)
- Quick Start Guide
- 6-foot power Adapter
- 2 screws and drywall mounts
