Light Codes (Rachio 3)
Last Update:Apr 9 2025 8:55pm • Est. Read Time:Est. Read Time: 6 MIN
Controller offline? Having issues with Wi-Fi on your controller? Our in-app help tool makes Wi-Fi troubleshooting a breeze! Tap Troubleshoot on the "Controller Offline" banner at the top of the Events page for automatic troubleshooting help. Follow the prompts in the app to identify what's wrong and how to quickly fix it.
What are light codes?
The Rachio 3 Smart Sprinkler Controller displays over 20 LED light codes that show the status of your controller. These light codes offer visual clues on what's happening with your controller at any given time.
Controller not working as expected? Light codes are a great first place to look, and can save you time in figuring out any issues!
How are light codes used?
The light codes in Rachio 3 are very useful in a variety of situations and can help you know or recognize:
  • When a particular zone is running, paused, or delayed.
  • Where your controller is within the Wi-Fi setup process (booting up, connecting to Wi-Fi, connecting to Rachio servers, or activating the controller).
  • Whether any errors are occurring or troubleshooting steps are needed.
  • And more!
Is the light bar on your Rachio 3 controller too bright? You can adjust the brightness!
Rachio 3 light code quadrants
What do light codes mean?
Use the tables below to identify the light code you are seeing, as well as any follow-up or troubleshooting steps needed.
Light codes can tell you a lot about the state of your controller, including:
  • Troubleshooting needs
  • Controller status
  • Current watering
What do light codes look like?
Find your controller's light code below to find out what it means, whether an action is required, and what to do if troubleshooting is needed.
Wi-Fi and Wi-Fi Troubleshooting light codes
Light Code Display
What It Means
What To Do
First light section blinking white
Booting Up - When the controller is booting up after restarting or power cycling, the first light section will blink white.
Status indicator (no action required)
First light section solid white, with second light section blinking yellow (first installation)
Awaiting Wi-Fi - When the controller is ready to connect to Wi-Fi, the first light section will be solid white with the second light section blinking yellow/amber.
Follow the instructions at: Rachio 3 Light Section 2 Flashing
First light section solid white, with second light section blinking yellow (after power cycle)
Reconnecting to Wi-Fi - If you're reconnecting to Wi-Fi, when the controller has restarted and is reconnecting with the pre-entered Wi-Fi credentials, the first light section will be solid white and the second light section will be blinking yellow/amber.
Status indicator (no action required), if this takes too long: Rachio 3 Light Section 2 Flashing
First light section blinks 9 times white, and 1 red
Boot Error One - If the first light section is blinking 9 times white and 1 red, this indicates a boot failure.
The controller may have experienced a memory error. Refer to the following article for next steps: Light 1 Troubleshooting.
The first light section is solid red
Boot Error Two - If the first light section is a solid red bar, contact Rachio Support.
Contact Rachio Support through: support@rachio.com
Second light section blinking 9 times white and 1 red
Awaiting Wi-Fi Error - The second light section will blink 9 times white and then 1 red to indicate an error connecting to the Wi-Fi network
A red light flash in the second section is likely to be an error when typing in the password/wifi name. Follow the instructions at: Rachio 3 Light Section 2 Flashing
First and second light sections are solid white light, with the third light section blinking white
Connecting Rachio to Server - The first and second light sections will be solid white, and the third light section will be blinking white
Third light section blinks 9 times white, and 1 red light
Connecting to Server Error - The third light section will blink 9 times white and 1 red to indicate an error connecting to the Rachio server
Troubleshoot Wi-Fi connection. This error code usually indicates a router setting preventing the controller from communicating outside of your Wi-Fi network. You can get more information through the following link: Light Section 3 Troubleshooting
The first 3 light sections are solid white, with the fourth section blinking white
Controller Registering - The first, second, and third light sections will be solid white, and the fourth light section will be blinking white until a full connection has been established.
Contact the Rachio Support Team through support@rachio.com so they can manually add the controller to the account.
Controller status light codes
Light Code Display
What It Means
What To Do
The whole light bar flashes blue once
Success - Any time the Rachio 3 accepts a command successfully, the entire light bar will flash blue
Light bar "breathing", alternating between full and diminished blue light
Idle - Controller is in idle state
Light bar shrinks from full bar of white light toward the middle
Shutting Down - When the controller is shutting down, the light bar will start out fully illuminated with a white light. The light will then shrink down to the middle of the bar. It will continue to provide this code until the controller reboots.
Light bar fills from left to right with white light, then the whole bar flashes blue (while holding the Wi-Fi button)
Wi-Fi Update - When holding down the Wi-Fi button, the entire bar will fill up from left to right with a white light. It will then flash blue to indicate that the controller is now moving to Wi-Fi update mode, then run the shutdown sequence light code
You can view more about this here: Rachio 3 Light Section 2 Flashing
Light bar entirely fills up from left to right with yellow light, then flashes blue
Factory Reset - When holding down the stop button, the light bar will fill up from left to right with a yellow light. It will then flash blue, then run the shutdown sequence light code.
How do I factory reset my controller?
Light bar displays one blue light in the middle, then splits
Direct Access - When the controller has been placed in direct access mode, the light bar will have one blue light in the middle that then splits into two lights that move away from each other toward the ends of the light bar.
Direct Access information.
Dim blue
Hibernation Enabled - When hibernation (formerly Standby) mode is enabled from the app, the light bar will be a solid dim blue color until the controller is awakened.
Hibernation mode information.
Light bar slowly filling up with light, with the end of the light bar blinking
Uploading Firmware - When the device is receiving a firmware upload, the light bar will slowly fill up with a white light with the end blinking. This is so the light bar works like a progress indicator for the download.
Green light with blinking tip
Installing Firmware - When the controller is installing firmware, there will be a green progress light with a yellow blinking tip.
Zone and watering status light codes
Light Code Display
What It Means
What To Do
Small blue light moving across light bar
Zone Selection - When selecting a zone to water from the controller, pressing the forward/back buttons will cause a small blue light to move across the light bar over the zone terminals to indicate which zone is selected.
Bright blue light pulsing over a particular zone
Zone Running - When a zone is running (commanded from the app or controller), there will be a bright blue light pulsing over the zone that is running.
Blue light bounces from left to right
Watering Paused - When a run is paused, there will be a blue light that bounces from left to right to left during the entire duration of the pause.
"Splashing" pattern of light moving away from the center of the light bar
Watering Delay Active - When a watering delay has been set, the light bar will replicate a raindrop by lighting a random area of the light bar, and then "splashing" the light away from the center.
Water Delay Information.
Pulsing red light over a particular zone section
Zone Fault - When the controller detects a zone fault, it will pulse a red light over the faulting zone number.
Inspect the zone fault and repair if possible.
Zone fault detection.
Looking for Generation 2 light codes? Click here!
8am-5pm (MST), Monday - Saturday.
We are closed on Thanksgiving, Christmas, and New Years Day.
