Wiring Label (Generation 1)
Last Update:Feb 25 2022 2:40pm
Not sure how to wire you Generation 1 Controller? No sweat! All you need is a small screwdriver for the installation! The controller is designed to accommodate two sensors, a master valve or pump relay, and up to 16 zones.
If you're having trouble reading the terminal labels, please reference the wiring guide below:
COLORWIRE
WhiteCommon (use any or all)
GreenZone # (reference old timer wiring)
BlueMaster Valve or Pump Relay; see  Advanced Wiring
YellowSensor (Rain)
Tips for Wiring:
  1. 24VAC and ground wires are not needed.
  2. An enclosure is required for hard wiring installations and/or outdoor installation.
  3. When inserting or releasing wires, push IN on the terminal block with a small screwdriver. This will ensure a solid connection.
  4. Solid 18 gauge single-strand copper wiring is ideal. If you have thicker gauge wires we recommend retrofitting with 18 gauge wires using a  terminal strip.
  5. Keep all wiring within the recessed triangular area of the Wall Mount. This ensures the Front Panel will properly attach.
