Rachio Wireless Flow Meter Tech Specs
Last Update:Feb 24 2022 5:10pm • Est. Read Time:Est. Read Time: 2 MINWondering what's inside our Rachio Wireless Flow Meter? Are you a Rachio Wireless Flow meter user? Wondering what's going to happen now since you still have your accessory although it's no longer manufactured by Rachio?
The good news is that we're still providing assistance for it, check this article!
What is the Rachio Wireless Flow Meter?
The Rachio 3 Smart Water System pairs leading smart sprinkler control with the precise flow monitoring of the Rachio Wireless Flow Meter to avoid catastrophic leaks and gain insight into your outdoor water use. The Flow Meter detects broken heads, ruptured pipes, and even low-flow leaks with highly-sensitive, state-of-the-art Vortex technology and is able to issue notifications for leaks and blockages (and even trigger instant zone shut-off when leaks are detected!).
To experience the Wireless Flow Meter’s effortless pairing with Rachio 3, preorder the Rachio 3 Smart Water System here!
Learn how to install the Rachio Wireless Flow Meter in under 1 hour!
Features
- Wireless communication to Rachio 3 controller for easy, low-cost installation
- No moving parts; safely blow out through the sensor
- Compatible with copper or PVC pipe
- Long battery life
- High accuracy
Specifications
Size | 1” |
Flow Range | 0.5 - 25.0 GPM (0.1 GPM resolution) |
Accuracy | RANGE 1.0 to 20.0 GPM: +/- 5% of reading RANGE 20.1 to 25.0 GPM: Usable Over-range; Accuracy Not Specified RANGE 0.5 to 0.9 GPM: Leak Detect Range; Flow can be detected but accuracy not specified RANGE 0.1 to 0.5 GPM: Flow cannot be detected, no usage will be reported. |
Pressure Loss at 20GPM | <1.5 PSI |
Burst Pressure | 350 PSI |
Operating Temperature | 32F to 120F |
Meter Body Material | ABS |
Power | Two AA batteries |
Battery Life | >2 years in typical use case |
Wireless Range | 330 ft open air; 75 ft underground |
The Wireless Flow Meter is not designed for potable water use and must be installed after a backflow preventer device.
Do you have a Rachio Wireless Flow Meter installed in your system? The flow meter is built for durability and can safely withstand winterization, blowout, and system maintenance. No need to mess with it once it's installed - carry on with winterizing as normal!
