Create a Fixed Schedule
Last Update:Apr 9 2025 8:59pm • Est. Read Time:Est. Read Time: 3 MINSummary
Once you have configured all of your zones, you will be asked if you would like to create a watering schedule. This article explains how to set up a Fixed Schedule. Watering times are the same as a program or schedule that you would run with an old controller. Want to learn how you can create a Fixed Schedule? This article is for you!
For Fixed and Flex Monthly users: If you have different vegetation types it is recommended that you setup separate schedules for each vegetation type. So, you would want to set up a separate schedule for shrub zones and a separate schedule for grass. Each vegetation type has its own unique watering needs. Because grass needs to be watered more often than shrubs, a single schedule will not serve both optimally. You can read more about Creating a Fixed Schedule and creating a Flex Monthly ScheduleStep-by-Step Guide
- From your "Schedules" tab, click on "Schedules" (located at the top of the screen), then click "Create Schedule" at the bottom of the screen.
- Select "Fixed" when you are prompted to select between a Flex Daily, Flex Monthly, or Fixed.
- From here you will be asked to choose the zones that you want to associate with this schedule. By default, all of your zones will be selected unless they are disabled. Tap the ones you want to check/uncheck.
- Name your Schedule. Type in a name that helps you identify your watering cycle. After your schedule is set up, your notifications will contain this schedule name.
- Select which days you will want the schedule to water.
a) "Specific Days" allows you to select any weekday(s) to water;
b) "Even/Odd Interval" waters either on even or odd calendar days, whatever you prefer;
c) "Daily Interval" allows you to select to water "Every Day", "Every 2 Days"... up to "Every 30 Days";
d) "Hourly Interval" waters more than once per day. You can select either "Every Hour", "Every 2 Hours... up to "Every 6 Hours". - Select when you would like your schedule to start or end watering. Choose one of the following: "End Before Sunrise" (recommended), "Start After Sunset", "End Before a Specific Time", or "Start at a Specific Time".
Selecting the option to “End Before a Specific Time” or "End Before Sunrise" can only be applied to one schedule per controller; this is to prevent multiple schedules from being stacked and eventually moving out of the 24-hour period of your selected watering day. - Select when you would like the schedule to start (today or another date) and when you would like your schedule to end. Its also possible to set a schedule to start and end on specific dates every year, or not to repeat at all.
- Decide whether you would like to activate Smart Cycle, Rachio's version of "Cycle and Soak."
Smart Cycle breaks up watering times by zone to prevent runoff and improve plant health based on soil type. Smart Cycle is recommended; however, you can also select "Manual cycle and soak" or opt out of both features. For more details, please see Smart Cycle FAQ. - Here you can select which Weather Intelligence features to activate.
Weather Intelligence is a collection of weather-rich "virtual sensors" that use forecast data to productively skip your schedules, helping you save water and make every gallon count! Go here to learn more about Rachio Weather Intelligence. - Based on previously entered information and Zone Settings, Rachio calculates your ideal watering duration(s). You can use the - and + buttons to change the suggested watering durations, but this could make your schedule less effective.
Scroll down and hit "Next" to confirm your schedule. - Tap "Done" to complete the process.
You're now the owner of a new Fixed Schedule! You can edit it at any time on the "Schedules" tab, through your Rachio app. For more details, please see: How do I edit a watering schedule?
