Professional Installation - Rachio Controller and Wireless Flow Meter Installation Checklist
Last Update:Oct 17 2023 6:36pm • Est. Read Time:Est. Read Time: 2 MINSummary
Are you a Rachio Pro looking for some guidance on how to install a Wireless Flow Meter? This support article is intended to assist irrigation professionals with the installation of Rachio Smart Sprinkler Controllers and the Rachio Wireless Flow Meter (only bundled with the Rachio 3 controller).
Additional Training
If you would like further training, you can use our free Rachio Pro program to access our pro-specific educational materials. Sign up here.
Installing the Rachio Wireless Flow Meter
The Wireless Flow Meter only works with the Rachio 3 controller. It is not compatible with the Generation 1 or 2.
Installation instructions, system compatibility, and a list of required fittings are available in the Rachio Wireless Flow Meter Quick Start Guide.
The flow meter is wireless and made of ABS. You must use Sharkbite or PVC-Lock connectors specific to the pipe size and material, you can find the guide to required fittings here.
Please note, you must know the customer's pipe size and material to find unique install guides and fittings required for installation.
For flow meter tech specs, click here.
You will pair the flow meter using the Rachio app. Your customer will “Share Access” to their account with you, then you will be able to control their system from your account. Download the Rachio app for iPhone or Android. Learn how to “Share Access” in this support article.
Installing Rachio Smart Sprinkler Controllers
Each generation of the controller has unique installation instructions, but use the same Rachio app for setup.
Indoor installation instructions:
Outdoor installation instructions:
Set up a new controller for your customer using the Rachio app
- Using your customer's email, set up a Rachio account within the app.
- Create a password for your customer.
- Install the Rachio controller and connect it to the customers' account.
- Use the app to setup zone information, schedules, and Weather Intelligence preferences.
- Have your customer download the Rachio app.
- Give your customer their login (email) and password.
- If you want to access your customer's account from your Rachio account, ask your customer to use “Shared Access” in the “More” menu, to allow you to view and modify schedules and settings.
