Rachio 3 Compatibility and Tech Specs
Last Update:Feb 6 2025 5:02pm • Est. Read Time:Est. Read Time: 2 MINSummary
This article will help you identify the technical specifications for your Rachio 3 and what is compatible with.
What's new with Rachio 3?
Rachio 3 offers many great improvements over our previous controllers:
- Supports dual-band Wi-Fi (2.4 GHz & 5 GHz)
- Easy-press connectors are easier to install than ever and support 14-22 gauge wires
- Rachio 3 Smart Sprinkler Controller
What's in the Rachio 3 box?
- Weight: 1.05 lbs
- Dimensions: 9.1" x 5.5" x 1.4"
- Power Supply with 6-ft Cord
- Mounting Hardware
- 4 screws (1-3/4" in length)
- 4 drywall mounts (1/4" diameter)
- Quick Start Guide
Rachio App Compatibility
- Click here for Rachio App Compatibility Requirements.
Wi-Fi Connection
- Requires 2.4 or 5 GHz wireless network signal available at the installation location
Power Requirements
- Power Supply: External Transformer. Replacement power supplies available here on Rachio.com
- (6-ft cord - 2.1mm x 5.5mm Female barrel plug)
- Transformer input: 120 VAC ~60Hz 300mA
- Transformer output: 24 VAC 850mA (0.85 Amp)
Zone output (24 VAC): Compatible with 24VAC Solenoids
Wire Compatibility
Rachio 3 supports 14-22 gauge wires.
Hardware Compatibility
Rachio 3 is compatible with:
- Master valve / pump relay
- 3rd Party Sensors
- Rain Sensor: Wired & Wireless Normally Closed (NC) sensors
- Soil Sensor: Wired & Wireless Normally Closed (NC) sensors
- Wired flow sensor (check compatibility)
Integrations
- Rachio 3 works with Amazon Alexa, Google Assistant, and others.
Zones/Model Numbers
- 4 zones (Model: 4ZULWC)
- 6 zones (Model: 6ZULWC)
- 8 zones (Model: 8ZULWC)
- 12 zones (Model:12ZULWC)
- 16 zones (Model: 16ZULWC)
Model numbers may have additional letters depending on the model, such as Pro Series, which contains PS at the end, or BLI in the case of Indoor Pro Series (that does not contain the weatherproof enclosure), or USI.
Warranty
- 2-year limited warranty.
Optional Outdoor Enclosure
Outdoor installations require an outdoor enclosure to protect your controller.
- Compatible with Rachio Outdoor Enclosure (Generation 2)
- Operating temperature: -13°F to 140°F
