# Using Apple Shortcuts with Rachio
> Amazon Echo Integration  Amazon Echo allows you to interact with Alexa Amazons voice control platform Alexa listens for her name followed by a   command  Wo
Source: https://support.rachio.com/en_us/using-apple-shortcuts-with-rachio-H12ulHbEp
Last updated: 2026-04-21T13:30:08.730Z
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/eece8911e700068c1f461f67d1b569e0.png)
### Summary
Rachio integrates with Apple Shortcuts, which allow you to control your Rachio 3 sprinkler controller directly from your iPhone's home screen. Apple Shortcuts can be triggered with the Siri voice assistant or through the [Apple Shortcuts app](https://apps.apple.com/us/app/shortcuts/id915249334).
### Related Articles
*   [Using Alexa with Rachio](https://support.rachio.com/SkKkuI1FD)
*   [Using Google Home with Rachio](https://support.rachio.com/r1Fyu8JKP)[](https://support.rachio.com/H12ulHbEp)
*   [Using IFTTT with Rachio](https://support.rachio.com/Sy91OU1FD)
*   [Using Alarm.com with Rachio](https://support.rachio.com/BkakdIJYv)
*   [Using Control4 with Rachio](https://support.rachio.com/HkAk_LJFD)
*   [Using Nexia with Rachio](https://support.rachio.com/Byayd81Yv)
Rachio integration with the Shortcuts app is only available on Apple devices with iOS 17 and higher.
There are two ways to use Shortcuts with your Rachio products. You can use the default voice command "Siri, run my Rachio!", or you can create a custom Shortcut.
### Using the default voice command:
1.  To use the default voice command, activate Siri on your Apple device and say: "Siri, run my Rachio!".
2.  You will then be prompted by Siri to select (either verbally or by tapping on the screen) which Rachio Property, Device, and Zone/Valve you would like to run.
3.  Lastly, Siri will ask you how long you'd like to run the Zone or Valve for. You can reply with the duration (in minutes) that you'd like to water for.
### Creating a custom Shortcut:
1.  To use a custom Shortcut, you will first need to _create_ the shortcut. Refer to Apple's support documentation if you are unfamiliar with creating custom Shortcuts.
2.  Open the Shortcuts app on your Apple device and click the + icon in the top right corner.
3.  Select "+ Add Action", then tap "Apps" and then scroll down and tap the Rachio app.
4.  Tap the "Water with Rachio" action, and enter the specifications for the "Property", "Device", "Zone", and "Duration (in minutes)" variables for the action.
5.  When you want to run the Shortcut, activate Siri and say, "Water with Rachio!"
[↑ Go to Top](# "Go to top")
