Rachio Wireless Flow Meter Shopping Guide
Last Update:Oct 17 2023 7:52pm • Est. Read Time:Est. Read Time: 3 MIN
Do you need guidance in regards to what to buy for your installation? Wondering what's going to happen now since you still have your Rachio Wireless Flow Meter although it's no longer manufactured by Rachio?
The good news is that we're still providing assistance for it, check this article!
Shopping Guide
We know there are a lot of options out there for purchasing the supplies needed to install the Rachio Wireless Flow Meter. That's why we've put together this handy shopping guide, with a list of required supplies to help take the guesswork out of your installation!
Important
  • Rachio recommends professional installation; however, we provide installation instructions for handy people with DIY skills.
  • Rachio recommends specific installation instructions based on your pipe size and material. Using any installation methods other than those recommended could damage the Wireless Flow Meter or void the warranty. Using glue of any kind will damage the flow meter.
  • While installation times average 30 minutes, we recommend allowing 2 hours for completion.
Check your system's specifications by matching the size (1 inch or 3/4 inch) and material (PVC, PEX, or copper) of the pipes between your backflow preventer and valve box. Then click the links below for purchasing information.
Necessary fittings will vary by the system - double-check your setup prior to purchase for a smooth installation!
Please note that links to purchase pages may be broken as store inventory changes.
1-inch PVC
You will need to purchase two of the appropriate fittings in order to complete the installation.*
1-inch PVC lock fittings (*purchase 2)
Recommended Pipe Cutters
¾-inch PVC
You will need to purchase one or two of each appropriate fitting in order to complete installation.*
¾-inch to 1-inch PVC lock fittings (*purchase 2)
1-inch PVC lock fitting (*purchase 1)
Required pipe transition
A 6-inch cut piece of 1-inch PVC pipe. Available at Home Depot, Lowe's, or Amazon. You may need to purchase a longer piece and cut it yourself.
1-inch copper or 1-inch PEX
You will need to purchase two of the appropriate fittings in order to complete installation.*
1-inch copper to 1-inch PVC Sharkbite fittings (*purchase 2)
¾-inch copper or ¾-inch PEX
You will need to purchase one of each of the appropriate fittings in order to complete the installation.*
One, ¾-inch copper to 1-inch copper Sharkbite fitting (*purchase 1)
One, 1-inch copper to 1-inch PVC Sharkbite fitting (*purchase 1)
One, 1-inch PVC to ¾-inch copper Sharkbite fitting (*purchase 1)
  • Sharkbite brand, SKU # 25551LF
  • Available at Home Depot, Supply House, and Amazon
  • Note
    Make sure to only use the Rachio required fittings listed here. The Wireless Flow Meter is not compatible with Sharkbite fitting # U060LFZ, as it is intended for CTS-sized pipe (while the flow meter is sized for NPS).
A 6-inch cut piece of 1-inch copper pipe.
  • Available at any Home Depot.
  • You may need to purchase a longer piece and cut it yourself.
Make a mistake during installation?
Oops! Did you install the flow meter upside down, or remove too much (or too little) pipe? While the fittings can be removed from the pipe, removing them from the flow meter will require a special tool to remove.
Optional coupler removers
Select the coupler removers that fit your irrigation setup:
