# Rachio Smart Lighting Controller: Getting Started
> The Rachio Smart Lighting Controller (SLC) is a next-generation, Matter-enabled device that brings smart control to your low-voltage outdoor lighting.
Source: https://support.rachio.com/en_us/rachio-smart-lighting-controller-getting-started-SJfQkMSvll
Last updated: 2026-04-13T19:28:09.968Z
The Rachio Smart Lighting Controller (SLC) is a next-generation, Matter-enabled device that brings smart control to your low-voltage outdoor lighting. Whether you’re setting up your controller for the first time, connecting it to your favorite smart home platform, or troubleshooting common issues, this guide is your one-stop resource for everything you need to know.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/c4042aca50024ca55bbd1557af8ffbda.png)
This article covers installation basics, app features, smart home integrations, and more—along with helpful troubleshooting tips and frequently asked questions. If you're looking for specific setup steps for Google Home, Alexa, Apple Home, or other troubleshooting, check out our Related Articles section below the table of contents.
1.  [What Is the Rachio Smart Lighting Controller?](#what-is-the-rachio-slc)
2.  [Installation Overview](#installation-overview)
3.  [Connecting to the Rachio App](#connecting-to-the-rachio-app)
4.  [App Features Overview](#app-features-overview)
5.  [Matter & Smart Home Overview](#matter-and-smart-home-overview)
6.  [Troubleshooting Tips & LED Indicators](#troubleshooting)
7.  [FAQ](#faq)
### Related Articles
*   [Installing and Wiring the Rachio Smart Lighting Controller](https://support.rachio.com/Hkt23q5Dll)
*   [Feature Overview: Automations, Scenes, Areas & Dimming](https://support.rachio.com/ryCmUvUegx)
*   [Troubleshooting Guide & LED Reference](https://support.rachio.com/HkzY8BAwgg)
*   [Smart Home Integrations & Connecting with Matter](https://support.rachio.com/rJ0aoGSJlx)
*   [Compatibility & Tech Specs](https://support.rachio.com/H1zpWbBDex)
## What Is the Rachio Smart Lighting Controller?
The Rachio Smart Lighting Controller (SLC) is a smart, app-connected outdoor lighting transformer that gives you full control over your low-voltage landscape lighting. Designed for both easy retrofits and new installations, the SLC brings automation, customization, and seamless smart-home integration to your outdoor lighting setup.
This controller supports up to three individually controlled zones and delivers a total of 200 watts of lighting output. It connects to the Rachio app over Wi-Fi and is fully Matter-compatible, allowing you to integrate it with popular Matter-enabled smart-home platforms such as Google Home, Amazon Alexa, Apple Home, and many more. A Matter-enabled hub is required for all smart-home platform integrations.
### Key Features:
*   **Smart App Control** – Turn zones on or off, dim lights (with compatible bulbs), and create automations or scenes from your mobile device.
*   **Flexible Installation** – Works with 12V–15V lighting systems using 10–24 gauge wire.
*   **Weather-Resistant Design** – IP65-rated housing allows outdoor installation with no additional enclosure required.
*   **Matter-Compatible** – Seamlessly integrates with your existing smart home ecosystem via any Matter-enabled hub.
*   **Built-In Safety** – Includes over-temperature shutoff, over-current protection, and automatic recovery after power loss.
Whether you’re replacing an outdated transformer or building a new lighting system from scratch, the Rachio SLC makes it easy to bring reliable, smart automation to your outdoor spaces.
## Installation Overview
The Rachio Smart Lighting Controller is designed to be as installation-friendly as possible—whether you’re retrofitting an existing low-voltage lighting system or building a new one from scratch.
This section provides a high-level overview of what to expect during installation. For step-by-step instructions, view our support article: [Installing and Wiring the Rachio Smart Lighting Controller](https://support.rachio.com/Hkt23q5Dll).
### Installation Types:
*   **Retrofitting an existing system**
    *   Replace your current transformer with the SLC
    *   Reuse existing fixtures and wires by connecting them directly to the SLC’s three zone terminals
*   **New installation**
    *   Plan fixtures, bulbs, wire gauge, and total wattage before you begin
    *   SLC supports 12V–15V systems using 10–24 AWG wire
### Power Requirements:
*   Plugs into any standard 120V outdoor outlet via the built-in 3-foot power cord
*   **Do not** route power through a dimmer module or intermediary device—this may interfere with operation or damage the unit
*   No hardwiring or external transformer needed: just plug and play
### Outdoor Installation Ready:
*   IP65-rated internal components withstand rain, snow, and temperature extremes
*   Includes mounting hardware and mounting plate for quick installations
*   Compact, lightweight design fits in tight spaces without an additional enclosure
## Connecting to the Rachio App
Setting up your Rachio Smart Lighting Controller in the Rachio app is quick and intuitive. The controller uses Bluetooth for initial setup and dual-band Wi-Fi for ongoing connectivity.
### Step-by-Step Onboarding:
1.  Plug in your controller and ensure the LED light begins blinking yellow.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/e1bade40d8723750d509866e510a590c.gif)
2.  Open the Rachio app on your Android or iOS device.
3.  From the Devices screen, tap "+" to add a new device and select Lighting Controller.
     ![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/2ad7e4c5c385d79a5ab5be357e3baf71.png)![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/580d3c7c2ca1943c1ee2fe8376bd0208.png)
4.  Open the controller’s front plate. Then tap “Scan QR Code” in the app and scan the QR code using your device.
5.  Read and follow the in-app prompts to connect the Smart Lighting Controller to the Rachio App.
6.  Once connected, the LED will turn solid green, indicating a successful setup.
### Tips:
*   Your mobile device **must be connected to the same Wi-Fi network** you want the controller to join.
*   **Make sure Bluetooth and Location Services are enabled** on your mobile device.
*   Some Matter hubs are always looking for new Matter devices to add to their network. If your mobile device automatically prompts you to pair SLC before beginning the connection process in the Rachio app, cancel the prompt, and continue in the Rachio app.
Once onboarding is complete, the controller will appear in your device list in the app. From there, you can assign names to each zone, begin setting automations, and start using advanced features like dimming, scenes, and areas.
For more info on smart home integrations, see the [Smart Home Integration & Connecting with Matter](https://support.rachio.com/rJ0aoGSJlx) article.
## App Features Overview
Once your Rachio Smart Lighting Controller is connected to the Rachio app, you’ll unlock powerful tools to customize and automate your outdoor lighting. The app offers zone-by-zone control, advanced scheduling, and flexible organization options, whether you're managing a single controller or multiple devices across your property.
### Core Features Available in the App:
*   **Manual Zone Control**
    Instantly turn individual lighting zones on or off, or adjust brightness (with dimmable bulbs) directly from the app.
*   **Scenes**
    Create customized lighting presets across one or more zones—for example, “Evening Mode” might set Zone 1 to 30%, Zone 2 off, and Zone 3 to 100%. You can activate scenes manually or schedule them using Automations.
*   **Automations**
    Automate lighting based on time of day, including support for sunset/sunrise using your location. You can set start/stop times, offset those times up to 2 hours before or after sunset and sunrise, and choose specific days of the week for each automation to run.
*   **Areas**
    Group multiple Smart Lighting Controller zones together under a single “Area,” allowing for coordinated control, and shared automations across zones and on different devices.
*   **Real-Time Monitoring & Alerts**
    View live wattage usage and receive email notifications for key events—like an offline controller, or overload and temperature warnings.
*   **Device Customization**
    Name each controller and zone; assign icons or pictures to your zones. Set default brightness levels, dimming ranges, and enable dimming (for dimming-compatible bulbs and fixtures).
All features are available via the Rachio app on iOS and Android. New app enhancements are rolled out regularly, so be sure to keep your app up to date for the best experience.
## Matter & Smart Home Overview
The Rachio Smart Lighting Controller is one of the first outdoor lighting products to support **Matter**, the new smart home standard designed for greater compatibility, reliability, and security across platforms.
Using Matter, the SLC integrates with major smart home systems—including **Google Home, Apple Home, Amazon Alexa, and more**—through a single unified protocol. This allows you to control your lighting alongside other smart home devices, create routines, or issue voice commands from your preferred platform.
### Key Integration Details:
*   **Matter Support at Launch**
    The SLC comes Matter-enabled out of the box. If you set up the controller using the Rachio app, you can still **add it to your Matter ecosystem later at any time**.
*   **Platform Compatibility**
    *   **Apple Home**: Requires a certified Apple hub (HomePod, Apple TV w/ Matter support), or a mobile device using iOS18 or higher).
    *   **Google Home**: Works with Matter-compatible Android phones and Google hubs.
    *   **Amazon Alexa**: Compatible with Matter-enabled Alexa devices like Echo (4th Gen) or newer.
    *   **Other Platforms**: Compatible with Matter-enabled hubs.
*   **Use Cases**
    *   Control zones via voice (e.g., “Turn on the backyard lights”).
    *   Add SLC zones to smart home routines and automation scenes.
    *   Control lighting across brands and device types within a single platform.
### Thread Border Router Not Required
The SLC uses Wi-Fi and Matter-over-Wi-Fi at launch. It does not require a Thread Border Router or act as one.
**For complete setup guidance and specific cross-platform pairing instructions, refer to the [Smart Home Integrations & Connecting with Matter](https://support.rachio.com/rJ0aoGSJlx) article.**
## Troubleshooting Tips & LED Indicators
If something isn’t working as expected with your Rachio Smart Lighting Controller, this section can help identify the issue and guide you toward a resolution. Many problems can be diagnosed by checking the controller’s **LED status light**, which provides real-time feedback on the device’s status.
### LED Status Lights
*   **Blinking Yellow (initial)** – Ready to onboard.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/ad1700fa9c7724ab1871ce503992f9f2.gif)
*   **Solid Blue** – Connected via Bluetooth, but not yet connected to Wi-Fi.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/8ec83116e13d3da5898894f64f9bd17e.png)
*   **Blinking Yellow (during pairing)** – Connecting to Wi-Fi.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/70f7c8371f6dad68dbaa54e4c80f4812.gif)
*   **Blinking Blue** – Wi-Fi is connected, but the controller is not yet connected to Rachio’s servers.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/13b2c42d85eabc3a32d927463c941e50.gif)
*   **Green/Blue** – Pairing window is open; device is in the process of finalizing connection.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/76c40a3ea5617460fc81b9f31e03ccb3.gif)
*   **Solid Green** – Successfully connected and online. This is the controller’s default connected state.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/a37342b905715efe1f3f08ba1093536a.png)
### Common Issues & Troubleshooting Tips
#### Device doesn’t appear in the app after onboarding
*   If the controller's LED is solid green, it is connected to Rachio, or another Matter platform.
*   Refresh the Rachio App to see if the SLC appears.
*   If it does not appear, it's likely the SLC is already connected to a different Matter-enabled smart home app (Apple Home, Google Home, Amazon Alexa, etc.)
*   View the our [Troubleshooting Guide](https://support.rachio.com/HkzY8BAwgg#stuck-solid-green) for specific steps to rectify this issue.
#### Wi-Fi connection issues
*   Ensure your Wi-Fi network is 2.4GHz or 5GHz and that your phone (and Matter Hub if applicable) is on the same network during setup.
*   Power-cycle the controller, or use the app to reconnect it to Wi-Fi if the connection drops.
#### Controller not responding or appears offline
*   Check your home’s Wi-Fi router and internet connection.
*   Try rebooting the controller by unplugging it and plugging it back in.
*   If the LED does not reach solid green, reconnect to wifi using the in-app flow in the controller's settings.
#### Lights not turning on/off as expected
*   Check for loose wire connections at the controller terminals.
*   Confirm bulbs are compatible and functioning.
*   Ensure zone settings, brightness, or automations in the app are not unintentionally overriding expected behavior.
#### Dimming issues
*   **Only dimmable bulbs and fixtures are compatible with dimming features.**
*   Double-check the dimming range and default brightness settings in the app.
For additional troubleshooting steps and LED status information, visit our [Troubleshooting Guide](https://support.rachio.com/HkzY8BAwgg) or reach out to Rachio Support for assistance.
## FAQ
Quick answers to common questions that help clarify setup, usage, compatibility, and capabilities of the Rachio Smart Lighting Controller.
### General Questions
*   **Can I use the Smart Lighting Controller indoors or in a covered structure?**
    Yes. While the SLC is designed and rated for outdoor use, it can also be installed in garages, sheds, or other covered areas.
*   **Is the SLC weatherproof out of the box, or does it need an enclosure?**
    The controller is weather-resistant and IP65-rated for outdoor use. No additional enclosure is required—even in rainy or snowy environments.
*   **Does the controller store automations if my Wi-Fi goes out temporarily?**
    Yes. Once your automations are saved in the controller, they will continue to run even if Wi-Fi is unavailable. However, remote access and real-time control through the app will require an active internet connection.
### Product Compatibility
*   **What types of lighting systems are compatible with the SLC?**
    The SLC works with low-voltage (12V–15V) landscape lighting systems. It supports LED, halogen, and incandescent bulbs, provided the total wattage remains within supported limits.
*   **Can I use both LED and halogen lights with the controller?**
    Yes. You can mix bulb types within your system, as long as each bulb is compatible with your transformer voltage and within the zone’s power capacity. The same bulbs should be used within each individual Zone.
*   **What is the total wattage limit for each zone and for the whole controller?**
    Each controller supports up to three zones and a combined total of 200 watts. There is no per-zone wattage cap, as long as the combined total across all active zones does not exceed 200W.
### Features & App Behavior
*   **How many zones does the SLC support?**
    Each controller supports three individually controlled zones, with separate wiring terminals for each.
*   **Can I use the app to control multiple controllers at different locations?**
    Yes. The Rachio app supports multiple controllers across one or more properties. You can manage them all from a single account and switch between property locations within the app.
*   **What’s the difference between a Scene, an Automation, and an Area in the app?**
    *   **Scene** – Sets specific lighting states (e.g. brightness per zone) that you can activate manually, or on a schedule using Automations.
    *   **Automation** – Automatically turns lights on/off at set times or relative to sunset/sunrise.
    *   **Area** – Groups multiple zones and/or controllers for synchronized control. Can also be used within an Automation.
### Smart Home Integration
*   **What platforms does the SLC support through Matter?**
    The SLC is compatible with Apple Home, Google Home, Amazon Alexa, and other Matter-enabled platforms.
*   **Can I control my lights using voice assistants like Alexa or Google Assistant?**
    Yes. Once the SLC is paired with a Matter-compatible platform, you can use voice commands to control zones, activate scenes, or check the on/off status of your lights.
*   **Do I need to add the controller to my smart home app during setup, or can I do it later?**
    You can add the controller to your smart home platform at any time. The Matter setup code (QR or numeric) is printed on the device and is also available in the Rachio app after onboarding. On Android devices, Pairing Mode can be accessed in the controller's settings in the Rachio app once paired to Rachio. For iOS devices, the SLC can be paired directly to the Apple Home app by "adding a new accessory".
### Installation & Power
*   **How is the SLC powered?**
    The controller plugs into a standard 120V outdoor outlet using its built-in 3-foot power cord. No external transformer is needed.
*   **Does it require hardwiring or an external transformer?**
    No. The SLC is a plug-and-play device. It converts 120V AC to low-voltage output internally and does not require additional transformers or electrical work.
*   **Where can I mount the controller?**
    The compact housing supports wall, fence, or post mounting in a variety of orientations. Mounting hardware and mounting plate are included in the box.
7am-6pm (MST), 7 days a week.
8am-5pm (MST), Monday - Saturday. We are closed on Thanksgiving, Christmas, and New Year's Day.
[Go to Top ^](#top)
