# Rachio Manuals and Resources
> Looking for more information about our products? Here in this article, you're able to check our whole list of products with manual and resources.     Current...
Source: https://support.rachio.com/en_us/rachio-manuals-and-resources-rkCSP81Yw
Last updated: 2026-04-14T00:18:31.103Z
Looking for more information about our products? Here in this article, you're able to check our whole list of products with tech specs, manuals, and resources.
## Contents:
1.  [Rachio 3 & 3e Smart Controller](#section-1)
2.  [Rachio Gen 2 Smart Sprinkler Controller](#section-2)
3.  [Rachio Gen 1 Smart Sprinkler Controller](#section-3)
4.  [Rachio Smart Hose Timer](#section-4)
5.  [Outdoor enclosure](#section-5)
6.  [Software and other features](#section-6)
7.  [Wireless Flow Meter](#section-7)
# Rachio 3 & 3e Smart Controller
*   [Installation video](https://www.youtube.com/watch?v=ya8JHP-GeeY)
*   [Wi-Fi and app setup](https://www.youtube.com/watch?v=Pw71x6HWlqE)
*   [Wi-Fi reset](https://www.youtube.com/watch?v=kM81tGt9LyM&t=13s)
*   [Quick Start Manual \[PDF\]](https://rachio-support-media.s3.us-west-2.amazonaws.com/Knowledge+Base/Rachio+3+/Rachio+3+Smart+Sprinkler+Controller+Installation+Guide.pdf)
*   [Spec sheet for builders \[PDF\]](https://rachio-support-media.s3.us-west-2.amazonaws.com/Knowledge+Base/Rachio+3+/Technical_Specs.pdf)
## Tech Specs
### **What's in the Rachio 3 box?**
*   Rachio 3 Smart Sprinkler Controller
    *   Weight: 1.05 lbs
    *   Dimensions: 9.1" x 5.5" x 1.4"
*   Power Supply with 6-ft Cord
*   Mounting Hardware
    *   4 screws (1-3/4" in length)
    *   4 drywall mounts (1/4" diameter)
*   Quick Start Guide
### **Rachio App Compatibility**
*   **Apple iOS:** The Rachio app requires a phone or tablet running iOS 16.0 or later.
*   **Android:** The Rachio app requires a phone or tablet running Android 8.0 or later.
Please note: the Rachio mobile app is required to connect devices to Wi-Fi.
### **Wi-Fi Connection**
*   Requires a 2.4 or 5 GHz wireless network signal available at the installation location
### **Power Requirements**
*   Power Supply: External Transformer. Replacement power supplies are available [here on Rachio.com](https://rachio.com/products/controller-power-supply/)
*   (6-ft cord - 2.1mm x 5.5mm Female barrel plug)
*   Transformer input: 120 VAC ~60Hz 300mA
*   Transformer output: 24 VAC 850mA (0.85 Amp)
Zone output (24 VAC): Compatible with 24VAC Solenoids
### Wire Compatibility
Rachio 3 supports 14-22 gauge wires.
### Hardware Compatibility
Rachio 3 is compatible with:
*   Master valve/pump relay
*   3rd Party Sensors
    *   Rain Sensor: Wired & Wireless Normally Closed (NC) sensors
    *   Soil Sensor: Wired & Wireless Normally Closed (NC) sensors
*   Wired flow sensor ([check compatibility](https://support.rachio.com/en_us/connecting-a-wired-sensor-or-wired-flow-meter-to-a-rachio-sprinkler-controller-SyBRwLJYP))
### Integrations
*   Rachio 3 works with Amazon Alexa, Google Assistant, and others.
### Zones/Model Numbers
*   4 zones (Model: 4ZULWC)
*   6 zones (Model: 6ZULWC)
*   8 zones (Model: 8ZULWC)
*   12 zones (Model:12ZULWC)
*   16 zones (Model: 16ZULWC)
Model numbers may have additional letters depending on the model, such as Pro Series, which contains PS at the end, or BLI in the case of Indoor Pro Series (that does not contain the weatherproof enclosure), or USI.
### Warranty
*   2-year limited warranty.
### **Optional Outdoor Enclosure**
Outdoor installations require an outdoor enclosure to protect your controller.
*   Compatible with [Rachio Outdoor Enclosure](https://rachio.com/waterproof-enclosure/) (Generation 2)
*   Operating temperature: -13°F to 140°F
# Rachio Gen 2 Smart Sprinkler Controller
*   [Installation video](https://www.youtube.com/watch?v=craWnm9YdK0&feature=youtu.behttps://www.youtube.com/watch?v=CYcAGokig04&t=32s)
*   [Wi-Fi reset, Wi-Fi update](https://www.youtube.com/watch?v=CYcAGokig04&t=32s)
*   [Wi-Fi setup, troubleshooting, and light codes](https://www.youtube.com/watch?v=dfV9pssQeJ4&t=52s)
*   [Quick Start Manual \[PDF\]](https://rachio-support-media.s3.us-west-2.amazonaws.com/Knowledge+Base/Generation+2/RachioGeneration2-QuickStartGuide.pdf)
## Tech Specs
### Internet Requirements
This Rachio controller requires a 2.4ghz Wi-Fi internet connection (802.11 b/g/n).
Supported Wi-Fi encryption standards:
*   WPA2 (recommended)
*   WPA
Enterprise-level encryption is  _NOT supported_.
We recommend internet connections with a 1 Mb or higher upload speed for optimal performance.
In the event of a Wi-Fi outage or intermittency, the controller’s memory retains the last saved schedule received from the Rachio cloud and maintains the schedule until an update can be downloaded (_more info_ [here](https://rachio.kustomer.help/en_us/what-if-my-controller-goes-offline-SyboPIkFv)).
Wireless Module: AzureWave Technologies, Inc. IEEE 802.11b/g/n Smart Energy Module CU288 (FCC ID: TLZ-CU288)
### Power
*   Transformer Power Input: 120V AC / 60Hz
*   Transformer Power Output: 24V AC (1000 mA  _= 1 Amp)_
*   Designed For 24V AC Solenoids
*   Power Supply: External Transformer (6 ft cord)
*   Power Supply Housing: 2-1/8" 3-1/8" x 1-3/4"
In the event of a power outage, the system will not run. Account, zone, and schedule settings will be saved in the Rachio cloud.
### Rachio App Compatibility
*   Apple iOS: The Rachio app requires a phone or tablet running iOS 16.0 or later.
*   Android: The Rachio app requires a phone or tablet running Android 8.0 or later.
*   8 zones (8ZULWB)
*   16 zones (16ZULWB)
### Size and weight
*   Dimensions: 9.25” L x 5.625” H x 1.625” W
*   Weight: 1.2 Lbs
### Environmental
*   Indoor Installation ([Outdoor Installation with Enclosure](https://rachio.kustomer.help/en_us/how-do-i-install-a-rachio-controller-outdoors-weatherproof-outdoor-enclosure-r1LPLktv))
*   Temperature Range: -31F - 140F
### Sprinkler Compatibility
*   Zone Capacity
    *   16 zones + Master Valve/Pump Relay (Need more than 16 zones? Check our article: [Wiring a Master Valve, Pump, or Common Wire to Two Controllers](https://support.rachio.com/BkhiPIJFD))
*   Rain Sensor
    *   [Wired & Wireless](https://support.rachio.com/en_us/connecting-a-wired-sensor-or-wired-flow-meter-to-a-rachio-sprinkler-controller-SyBRwLJYP#section-2) Normally Closed (NC) sensors
*   Soil Sensor
    *   [Wired & Wireless](https://support.rachio.com/en_us/connecting-a-wired-sensor-or-wired-flow-meter-to-a-rachio-sprinkler-controller-SyBRwLJYP#section-4) Normally Closed (NC) sensors
*   Flow Sensor
    *   [Compatible Sensors](https://support.rachio.com/en_us/connecting-a-wired-sensor-or-wired-flow-meter-to-a-rachio-sprinkler-controller-SyBRwLJYP#section-3)
### Warranty
*   [2 Year Limited](http://rachio.com/warranty)
###  **In the box**
*   Rachio Controller (Cover + Base)
*   Quick Start Guide
*   6-foot power Adapter
*   4 screws and drywall mounts (1-3/4" in length, 1/4" diameter)
# Rachio Gen 1 Smart Sprinkler Controller
*   [Installation Video](https://www.youtube.com/watch?v=5XrT56PdhRY)
*   [Quick Start Manual \[PDF\]](https://s3.amazonaws.com/helpscout.net/docs/assets/5355b85be4b0d020874de960/attachments/559c098ce4b0b0593824ab73/rachio-easy-install-guide.pdf)
## Tech Specs
*   WPA
Enterprise-level encryption is _NOT_ supported.
We recommend internet connections with a 1 mb or higher upload speed for optimal performance.
In the event of a WiFi outage or interruptions, the controller’s memory retains the last saved schedule received from the Rachio cloud and maintains the schedule until an update can be downloaded. (  _more info_   [here](https://rachio.kustomer.help/en_us/what-if-my-controller-goes-offline-SyboPIkFv)  )
### Power
### Model Numbers
*   16 zones (16ZULW)
*   8 zones (8ZULW)
### Size and weight
*   Dimensions: 2.165” x 7.25” x 7.25”
*   Weight: 2.7 Lbs
### Environmental
*   Indoor Installation only (no outdoor enclosure available for Gen 1 controllers )
*   Zone Capacity
*   Rain Sensor
*   Soil Sensor
*   Flow Sensor
    *   Not supported on Generation 1 controllers
### Warranty
###  **In the box**
*   Rachio Controller (Wallmount + Front Panel)
*   Quick Start Guide
*   2 screws and drywall mounts
# Rachio Smart Hose Timer
*   [Manual \[PDF\]](https://rachio-support-media.s3.us-west-2.amazonaws.com/Knowledge+Base/Smart+Hose+Timer/hose-timer-manual.pdf)
## Tech Specs
# Outdoor enclosure
*   [Installation video](https://www.youtube.com/watch?v=tvyU3jpPL08&t=1s)
*   [Manual \[PDF\]](https://rachio-support-media.s3.us-west-2.amazonaws.com/Knowledge+Base/Enclosure/rachio-enclosure-install-guide-2017-v3.pdf)
# Software and other features
*   [Schedule overview](https://www.youtube.com/watch?v=2lnSi5X5vY8&t=172s)
*   [Controller Status and Hibernation Mode](https://support.rachio.com/en_us/controller-status-and-standby-mode-HkH6wLyFP)
*   [Winterization](https://www.youtube.com/watch?v=P0Olr9T8m0E)
*   [Valve Monitoring](https://support.rachio.com/en_us/valve-monitoring-r18zQOnKs)
*   [Heat Wave Boost](https://support.rachio.com/en_us/heat-wave-boost-Hy3FNW5hyx)
# Wireless Flow Meter
*   [Installation video](https://www.youtube.com/watch?v=BICEn5pR2fE&feature=youtu.be)
*   [Underground installation video](https://www.youtube.com/watch?v=gOX695cU03g&feature=youtu.be)
*   [Manual \[PDF\]](https://rachio-support-media.s3.us-west-2.amazonaws.com/Knowledge+Base/Wireless+Flow+Meter/Rachio+3+Flow+Meter+User+Manual+V4.5.pdf)
*   [Tech specs](https://support.rachio.com/en_us/rachio-wireless-flow-meter-tech-specs-SyADD8JKD)
# **Do you still need help?**
7 am - 5 pm (MST), 7 days a week**.**
8 am - 5 pm (MST), Monday - Saturday. We are closed on Thanksgiving, Christmas, and New Years Day.
