# Rachio Irrigation Schedule Overview
> Summary  Now that you have your Rachio online and working, you may wonder how to create and edit a schedule to help you save water. In this article, we'll wa...
Source: https://support.rachio.com/en_us/rachio-irrigation-schedule-overview-HJrFP8yYD
Last updated: 2026-04-13T21:33:50.581Z
Once your Rachio Sprinkler Controller is online, it's time to create your schedules. This article provides a high-level overview of each type of watering schedule, how to create and edit them, and how disable Weather Intelligence features when creating a schedule.
## Schedule types
### [Smart Sprinkler Controller](https://support.rachio.com/HJrFP8yYD#ContentsItem1Title)
Rachio Smart Sprinkler Controller offers 3 types of schedules:
*   [Flex Monthly](https://support.rachio.com/ryGGSWcfZe) \- Adjusts monthly based on historical climate data; watering duration & interval (frequency) change takes place after the first watering in the following month.
*   [Flex Daily](https://support.rachio.com/ryGGSWcfZe) \- Adjusts daily based on soil moisture; watering schedules dynamically update on a zone-by-zone basis.
*   [Fixed Schedule](https://support.rachio.com/ryGGSWcfZe) - Waters when you want - either on particular days of the week, a set interval, or odd/even days. Ideal for users with strict watering restrictions.
### [Smart Hose Timer](https://support.rachio.com/HJrFP8yYD#ContentsItem2Title)
Rachio Smart Hose Timer offers two scheduling possibilities:
*   By day of the week - The schedule will run on the selected days of the week, for example: Monday, Wednesday, and Friday.
*   On a daily interval - The schedule will run every selected interval of days, such as every 3 days, or every 4 days. This will disregard which day of the week it is.
*   On an even/odd interval - The schedule will run every even day of the month (such as the 2nd, 4th, 6th, etc.) or odd day of the month (such as the 1st, 3rd, 5th, etc.)
Each schedule can also be configured to run multiple times per day if desired.
# Smart Sprinkler Controller
## Which schedule is right for me?
The ideal schedule type for you depends on your situation. Watch the video below to see which schedule may be best for your plants and watering goals.
### Video Overview - Schedule Types
<span class="fr-mk" style="display: none;">&nbsp;</span><span class="fr-mk" style="display: none;">&nbsp;</span><span class="fr-mk" style="display: none;">&nbsp;</span><span class="fr-mk" style="display: none;">&nbsp;</span><span class="fr-mk" style="display: none;">&nbsp;</span><span class="fr-mk" style="display: none;">&nbsp;</span><span class="fr-mk" style="display: none;">&nbsp;</span><span class="fr-mk" style="display: none;">&nbsp;</span>
## How to edit a schedule
Want to edit an existing schedule? You can edit your schedule at any time after it's created. In the Rachio app, tap the "Schedules" tab and select the name of the schedule you would like to edit. For more information and instructions on editing your schedules, go here: [How do I edit a watering schedule](https://support.rachio.com/r15XepFfbe#section-2)
## How to duplicate a schedule
If you'd like to duplicate an existing schedule, simply tap the kebab menu (three vertical dots) next to that respective schedule name and tap **Duplicate schedule**. Please see our [How to Duplicate Schedules](https://support.rachio.com/r15XepFfbe#section-3) article for more information.
## Schedules Settings Overview
For more information on schedule settings and how to edit them, go [here](https://support.rachio.com/r15XepFfbe).
1.  **Name (schedule name)
    **This is the name your schedule goes by, which you can create during schedule creation.
2.  **Type
    **This lists your schedule type (Flex Daily, Flex Monthly, Fixed)
3.  **Interval (days schedule can water)
    **This tells you what days you will allow the schedule to water (any days, specific days, or even/odd intervals). If you've chosen a Flex type of schedule and you do not have watering restrictions, choose "any days" for optimum water savings! Please note: Once a schedule is created for a Rachio Smart Sprinkler Controller, the Interval Type cannot be changed. If you'd like to change the Interval Type, you will have to create a new schedule with the desired Interval Type.
4.  **Zones (zone selection)
    **This tells you what zones are active on a given schedule.
5.  **Times (times of day your schedule can run)
    **This tells you when your schedule will begin or end.
    #### Why can I not select "end before" on some schedules?
    The option to “end before a specific time” or "end before sunrise" can only be applied to one schedule per controller; this is to prevent multiple schedules from being stacked and eventually moving out of the 24 hour period of your selected watering day. As a result, once this option has been applied to a schedule, the option will not appear when creating additional schedules. To change which schedule makes use of the "end before" option, go to "Schedule" tab > schedule name > "Times" > select when to start your schedule after or end it before
6.  **Watering Duration** This tells you how long your schedule will water for (in minutes).
7.  **Cycle and Soak/Smart Cycle
    **This tells you whether your schedule uses [Smart Cycle or manual cycle and soak](https://rachio.kustomer.help/en_us/smart-cycle-and-manual-cycle-and-soak-features-r1_FwL1Kw).
8.  **Weather Intelligence
    **Details which [Weather Intelligence™ Plus](https://support.rachio.com/B153wIJKD) features are active on your schedule.
## How to create a schedule without Weather Intelligence
Have a zone being used as a pool fill or in a part of your landscape that doesn't get a lot of rain or wind? Create a new schedule just for those zones and disable all Weather Intelligence features.
1.  **Create a new schedule
    **In the "Schedules" tab, tap on "Create Schedule" at the bottom of the screen.
2.  **Select schedule type
    **In order to create a schedule without Weather Intelligence, you'll need to select a Fixed Schedule.
3.  **Continue through the schedule setup
    **Follow the schedule setup to choose the zones you'd like to run without Weather Intelligence, name your schedule, select allowed watering days and times, and decide on Smart Cycle.
4.  **Disable all Weather Intelligence Skips
    **Eventually, you'll end up on the "Add Rachio Weather Intelligence" screen. Uncheck all Weather Intelligence options and tap Next. Finish up creating your schedule by approving or editing the duration.
# Smart Hose Timer
## Which schedule interval type is right for me?
It depends on your situation, how you use the system, and even on watering restrictions. By the day of the week, water will always be on the same, selected days of the week, while On a daily interval will follow the programmed behavior, such as every 3 days, or every 4 days, independently of which day of the week it is. Even/Odd days will water every other day based on the calendar number, which is a constantly used frequency and can suit watering restrictions if necessary.
On your Rachio app, select your Smart Hose Timer on the device selection screen, tap the Schedules tab at the bottom right corner, and go to EDIT.![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/9465ab03a73ab4cf97cbc41af921f892.png)
## Schedule Settings Overview
**1\. Enabled/Disabled**
This will enable/disable your schedule. Disabling it will not delete it, only prevent it from running. You can re-enable a schedule anytime you like.
**2\. Name**
The name your schedule goes by, which you can create during schedule creation.
**3\. Color**
Changes the schedule icon's color on the Home and Schedules tab, making it easier to differentiate them.
**4\. Valves in Schedule**
Allows you to change which valves are a part of this schedule.
**5\. Interval Type**
Here, you can edit your schedule's interval type between **By day of the Week** and **On a** **d****aily Interval**. Please note: The Interval Type can only be changed on the Rachio Smart Hose Timer. If you have a Rachio Smart Sprinkler Controller, you cannot change the Interval Type; you will instead need to create a new schedule with the desired Interval Type.
**6\. Time of the Day and Duration**
Changes the starting time and duration for each run. You can also increase or decrease the number of runs.
## How to create a schedule without Rain Skip
Under your Smart Hose Timer menu, tap the **\+ CREATE SCHEDULE** button. During the schedule creation, right after selecting interval type, durations, and days, the app will ask you if you want to **Skip this schedule when it rains**. Simply tap **No**.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/6721259d0a0e63da11f16a0794f12c32.png)
**We have a chat support team ready to assist you! You can submit a support request by selecting the chat icon in the bottom right of this page and a member of the support team will contact you live.**
**7am-5pm (MST), 7 days a week.**
**8am-5pm (MST), Monday - Saturday. We are closed on Thanksgiving, Christmas, and New Year's Day.**
