Rachio compatibility with RAIN BIRD SMRT-Y Soil Moisture Sensor
Last Update:Feb 24 2022 3:22pmNeed tips for your RAIN BIRD SMRT-Y Soil Moisture Sensor? The Rachio system doesn't require this accessory due to its integrated weather intelligence features, however, you can pair your rain sensor to the Rachio controller in case you want to keep it. This article will help you make sure it's correctly paired with our system.
Disclaimer
Rachio is NOT affiliated or authorized by RAIN BIRD; the RAIN BIRD brand soil sensors are manufactured by RAIN BIRD. This article is intended for instructional and compatibility purposes only.
Rachio and third-party sensors
Rachio does not recommend the use of 3rd party sensors unless required by local code. Rachio offers soil saturation management tools without the need for soil sensors by using Saturation Skip or Flex Daily Schedules to skip watering schedules BEFORE it rains based on estimated moisture levels.
Compatibility
The Rachio controller is compatible with the Rain Bird SMRT-Y Soil Moisture Sensor. It will operate similarly to a rain sensor when the moisture threshold is reached by interrupting the common wire and suspending all future watering events for the zone it's connected to until the soil moisture level dries out. There is no need to configure the sensor in the advanced settings.
SMRT-Y Soil Sensor
To install a SMRT-Y Soil Sensor, please reference the wiring diagrams below for assistance with the wiring on your Rachio controller. Please note that wiring colors may vary on your system.
