Rachio 3e Compatibility and Tech Specs
Last Update:Jan 4 2023 5:27pm • Est. Read Time:Est. Read Time: 2 MINYou might have noticed that our latest controller model the Rachio 3, has a slightly scaled-down, economical version, the Rachio 3e. Wondering what this controller is capable of doing? I would like to present you with Rachio 3e tech specs and compatibility.
Rachio 3e offers many great improvements over our previous controllers (Gen 1 and Gen 2):
Supports dual-band Wi-Fi (2.4 GHz & 5 GHz)
Easy-press connectors are easier to install than ever and support 14 gauge wires
What's in the Rachio 3e box?
Rachio 3e Smart Sprinkler Controller - Weight: 1.05 lbs
Dimensions: 9.1" x 5.5" x 1.4"
Power Supply with 6-ft Cord
Mounting Hardware4 screws (1-3/4" in length)
4 drywall mounts (1/4" diameter)
Rachio App Compatibility
Click here for Rachio App Compatibility Requirements
Wi-Fi Connection
Rachio 3e requires a 2.4 or 5 GHz wireless network signal available at the installation location.
Power Requirements
Power Supply: External Transformer
(6-ft cord - 2.1mm x 5.5mm Female barrel plug)
Transformer input: 120 VAC ~60Hz 300mA
Transformer output: 24 VAC 1000mA
Zone output (24 VAC): Compatible with 24VAC Solenoids
Wire Compatibility
Rachio 3e supports 14 gauge wires.
Hardware Compatibility
Rachio 3e is compatible with:
Master valve / Water Pumps & Pump Relays
3rd Party SensorsRain Sensor: Wired & Wireless Normally Closed (NC) sensors
Soil Sensor: Wired & Wireless Normally Closed (NC) sensors
Integrations
Rachio 3e works with Amazon Alexa, Google Assistant, and others. Find more at Rachio Smart Home Integrations.
Zone/Model Number
8-zone (Model: 8ZULW-C_LITE)
Optional Outdoor Enclosure
Outdoor installations require an outdoor enclosure to protect your controller. How do I install a Rachio Controller outdoors? Weatherproof Outdoor Enclosure
Compatible with Rachio Outdoor Enclosure
Operating temperature: -13°F to 140°F
Warranty
2-year limited warranty.
If a Rachio Pro sells and installs a professional edition of the Product, the warranty will be extended an additional 2-year, resulting in a warranty period of 4 years. https://rachio.com/warranty/
8am-5pm (MST), Monday - Saturday. We are closed on Thanksgiving, Christmas, and New Year's Day.
