Public API Documentation
Last Update:Mar 26 2024 4:04pmSummary
Rachio's public API has a rate-limiting in order to improve server performance for all users. We only allow 1,700 calls per day, which is over 1 call per minute. In general, this limit is only reached by integrations that are polling.
If you’d like to explore a non-polling method, we do support webhooks. We are absolutely willing to work with users to discuss exceptions on rate limiting for specific use cases.
Rate limiting is reset at midnight UTC and the response header can be viewed for the following data:
X-RateLimit-Limit – The limit that you cannot surpass in a given amount of time
X-RateLimit-Remaining – The number of calls you have available until a given reset timestamp, or calculated given some sort of sliding time window.
X-RateLimit-Reset – The timestamp in UTC formatted to HTTP spec per RFC 1123 for when the limits will be reset.
Example of response header data:
x-ratelimit-limit →1700
x-ratelimit-remaining →4
x-ratelimit-reset →2018-03-13T00:00:00Z
To learn more about our API token, check out our Rachio API Documentation
Want to find your API key?
Through the Rachio Web App, select "Account Settings". Then click on "GET API KEY".
Through the Rachio Phone App, select the "Profile" icon and then click on "API Key Copy".
This is available for both iOS and Android devices, please make sure to have the latest app version.
