Installation guide for Rachio Wireless Flow Meter: 1-inch copper pipe
Last Update:Oct 19 2023 8:01pm • Est. Read Time:Est. Read Time: 4 MINSummary
So you have a flow meter and your system has 1-inch copper pipes, right? You're probably wondering how to install the Wireless Flow Meter in those conditions. Look no more, we got you covered.
Above: Rachio Wireless Flow Meter on 1-inch copper pipe
Let’s get started!
Important
- Rachio recommends specific installation instructions based on your pipe size and material. Using any installation methods other than those recommended could damage the Wireless Flow Meter or void the warranty. Using glue of any kind will damage the flow meter.
- While installation times average of 30 minutes, we recommend allowing 2 hours for completion.
- If you cannot complete any of the steps, we recommend a professional installation.
Make sure your system meets the installation requirements:
- The installation site must be within 300 feet of an installed and set-up Rachio 3 Smart Sprinkler Controller.
- The backflow preventer and installation area must be above ground (recommended).
- The system must have a ¾-inch or 1-inch pipe made of either copper, PVC, or PEX.
- For 1-inch PVC pipe, or 1-inch copper pipe, and ¾-inch PVC pipe, you will need 14 inches of straight pipe between the backflow preventer and valve box.
- For ¾-inch copper pipe, you will need 16 inches of straight pipe between the backflow preventer and valve box.
Attention
The following Rachio Wireless Flow Meter installation instructions are intended only for irrigation systems with 1-inch copper pipe. If your system uses a different pipe size and/or material, please visit rachio.com/flow for instructions tailored to your system.
What’s in the box
- Rachio Wireless Flow Meter
- Battery cover
- 4 screws
What you’ll need
Installation instructions are intended only for use with required fittings.
- Recommended manual pipe cutter (listed below)
- Sandpaper or deburring tool
- Fine point permanent marker
- Stick ruler
- Phillips screwdriver
- Smartphone or tablet
Required parts and fittings for 1-inch copper
Required fittings:
- Two, 1-inch copper to 1-inch PVC Sharkbite fittings
- Sharkbite brand, SKU # UIP4020. Available at Home Depot, Lowe’s, Supply House, and Amazon.
Recommended pipe cutter:
For copper pipe: 1 in. Copper Tubing Cutter. Do not use a hacksaw or PVC ratcheting pipe cutter. Available at Home Depot and Amazon.
Take Note
Important
Using installation methods other than those recommended in this manual could damage the Wireless Flow Meter or void the warranty.
Warning
Inserting your fingers into the Flow Meter or fittings can damage equipment or cause personal injury.
Using glue of any kind could damage the Rachio Flow Meter.
Need some help?
- Check out our Help Center
- Give us a call: 1 (855) 300-3569
- If you’re unable to complete any of the installation steps, we recommend a professional installation.
Are you a visual learner? Preview the installation method in our video! These instructions are specific to 1-inch copper pipe installations.
Installation Instructions
Step 1: Pair Flow Meter
- Open the Rachio app. From the Settings Wheel, enter "Controller Settings" and select "Accessories" then add the Rachio Wireless Flow Meter. You will be guided through the pairing process and then prompted to continue installation using this digital manual.
Step 2: Turn the water off
- Drain the system by running any two zones for one minute each using the Quick Run feature in the Rachio App.
Step 3: Connect fittings
- Push the Flow Meter and fittings together firmly using a twisting action until the fitting (part #UIP4020) is nearly flush with the Flow Meter. One part #UIP4020 should be attached to each side of the flow meter.
Step 4: Measure and cut pipe
Instructions for cutting 1-inch copper pipe
- Identify 14 inches of continuous straight pipe between the backflow preventer and the valve box.
- Mark 6 inches after the start of continuous pipe (this is often after a joint); this will be the top cut.
- Mark 6 ¼ inches after the first mark; this will be the bottom cut.
- Put a small X next to the first two marks.
- Mark 1 ⅛ inches above the top mark to indicate insertion depth.
- Mark 1 ⅛ inches below the bottom mark to indicate insertion depth.
Accuracy is important here! Measure twice, and cut once.
Step 5: Cut and clean pipe
- Make a clean, straight cut on the two innermost marks (denoted with X’s).
- First, cut the top innermost mark.
- Next, cut the bottom innermost mark.
- Do not cut the pipe on the outer insertion marks.
- Use the deburring tool or sandpaper to remove rough edges and debris inside and outside the pipe.
Step 6: Install the flow meter
- Important: Install so the arrows on the side and face of the Flow Meter are oriented with the direction of water flow. (Water flows towards the valve box; towards the ground.)
- Push the flow meter, fittings, and pipe together firmly while twisting the fittings to the insertion marks.
- All Rachio recommended fittings swivel 360˚, allowing for easy directional adjustment of the flow meter after installation.
Step 7: Turn the water on
- Turn the water back on.
- Check the installation site for leaks. If there is a leak, turn the water off and make sure the fittings are pushed up to the body of the flow meter and insertion marks. If the leak cannot be remedied, visit rachio.com/leak.
Step 8: Calibrate zones for leak detection
- To enable real-time leak detection, you must calibrate the Rachio Wireless Flow Meter. In the app’s Settings Wheel, select "Controller Settings", then "Accessories,"; select the Rachio Wireless Flow Meter, and tap "Calibrate Flow Meter". Follow the app instructions to calibrate.
Congrats, you did it!
