How do I setup a PWS using CWOP?
Last Update:Feb 21 2022 5:20pm • Est. Read Time:Est. Read Time: 2 MIN
Are you wondering 'How do I set up a PWS using CWOP'? You can set up your PWS to connect to your Rachio controller through the  Citizen Weather Observer Program (CWOP). A thorough step-by-step process is outlined below.
  The core component of this solution is the Meteobridge, which requires hardware and software purchase. To check Meteobridge's compatibility with your weather station, go here
Here is a summary of what customer Aaron did (which only applies when using the AcuRite Internet Bridge).
1) Buy the Acurite 5in1 with Internet-Bridge from acurite.com. Get that installed and updated to your internet.
2) Next, buy the DLINK DIR-505L and flash it with new firmware from Meteobridge. Instructions and firmware can be found  here.
3) Now the DIR-505L is a Meteobridge. The firmware will work for 14 days without needing to buy a software license.
4) Next I needed to set up the wifi on the Meteobridge so that it is a client "WLAN mode" on my home's Wifi network. I checked the box for the "LAN Bridge," link  here.
5) Once this is working, plug in the Acurite internet-bridge into the ethernet port on the Meteobridge. The Meteobridge acts as a transparent bridge, and the Acurite bridge thinks it is just on the local lan. The Meteobridge "sniffs" the traffic from the Acurite bridge and this is how it is able to collect the weather information and send it to a weather network of my choice. Aaron selected "Acurite Internet-bridge" from the "Select Station"  menu.
6) Next, choose the weather station wanted to upload too. In this case, CWOP is the network that will get the data to the Rachio App, link here.
7) Sign up for a CWOP account here. Aaron had to email: CWOP-support@noaa.gov and request his account to be activated so just FYI.
8) Before you start uploading data you should update the "System" menu and put in your Latitude and Longitude and the "Select Station" menu to add your Altitude, because this data is sent to CWOP along with your weather data.
9) Once your data is uploading you will immediately see the updates at findu.com at  CWOP Search Tool.
10) The next step is getting the CWOP data sent to NOAA. When I contacted CWOP-support@noaa.gov, they replied that my station ID has been added to the "Active Member" list and would show up at NOAA in a few days. You can always check the list to see if your station is on there through this  link.
11) Once you're on the "Active Member" list you are now a part of NOAA. It took Aaron 5 days before we could see his station. The Active member list will also show the mapping between your "Call/CW" and "NWSID". The NWSID is the ID you will see in
