# Cycle and Soak Features for Rachio Irrigation Devices
> Summary  Now that you have your Rachio up and running, you may have had the chance to create a schedule. You may be wondering what is the C  ycle and soak te...
Source: https://support.rachio.com/en_us/cycle-and-soak-features-for-rachio-irrigation-devices-r1_FwL1Kw
Last updated: 2026-05-09T16:58:21.389Z
Rachio devices are capable of splitting total watering times into smaller segments to give the soil enough time to absorb the water. This helps you save even more water and avoid run-off, as no one likes to see water running onto the sidewalk during watering!
Soak features are available both for Rachio Smart Sprinkler Controllers and Rachio Smart Hose Timers.
1.  [Rachio Smart Sprinkler Controller](#section-1)
2.  [What is Smart Cycle?](#section-2)
3.  [What is manual cycle and soak?](#section-3)
4.  [How can I use Smart Cycle, manual cycle and soak, or edit my selection?](#section-4)
5.  [Smart Cycle FAQ](#section-5)
6.  [Rachio Smart Hose Timer - Smart Soak](#section-6)
## Rachio Smart Sprinkler Controller
Now that you have your Rachio up and running, you may have had the chance to create a schedule. You may be wondering what is the Cycle and soak technique and how does Smart Cycle uses it to improve efficiency. This article is for you!
Cycle and Soak is a proven landscaping and irrigation technique that splits up watering durations into multiple, short watering durations. This method **prevents wasteful and harmful water runoff while increasing plant health by encouraging deeper root growth**. By including Smart Cycle or manual cycle and soak in your watering schedules, you can prevent soil erosion, stop harmful lawn chemicals from washing into fragile rivers and streams, and even save money on your water bill!
#### This feature affects your total watering duration, but not the amount of water delivered.
With Smart Cycle activated, watering times may **seem** longer on the surface. But don't worry - **your schedules are not applying more water, just watering more efficiently**.
With Rachio, you can choose how to apply this technique to your watering schedule. You can select:
*   Rachio's **Smart Cycle** feature, which uses your unique zone settings in order to automatically apply cycle and soak technology to your schedule if needed.
*   **Manual cycle and soak**, which allows you to determine the soak and cycle times.
*   No cycle and soak
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/70314db507bd2648a14b4b4cf758739c.png)
## What is Smart Cycle?
Smart Cycle is Rachio’s implementation of the “cycle and soak” technique. It automates the cycle and soak process and removes the guesswork of how long to cycle and soak. It intelligently breaks up run times to maximize your watering capabilities. **Smart Cycle is recommended, and enabled automatically on all schedules**, but can be edited (see below for instructions).
The duration of the cycle and the soak times for each zone is calculated automatically by the Rachio, utilizing the zones unique zone settings. For example, a zone with a 14-minute run time may be irrigated for 7 minutes, and then turned off while the controller advances to irrigate another zone. While the second zone is being watered, the original zone has time to soak up all the water into its soil, thus preventing water runoff. Then, after the second zone cycle is complete, the original zone is then irrigated for the remaining 7 minutes to achieve the total 14-minute run time. This 14-minute run time may also be irrigated for 2 minutes, turned off while the controller advances to irrigate another zone, then irrigated 2 more minutes, continuing this pattern until 14 minutes is achieved.
## What is manual cycle and soak?
The manual Cycle and Soak feature allows you to do the same thing as Smart Cycle (split up watering durations into multiple shorter watering durations), except that you define the parameters instead of Rachio doing this for you. Unlike Smart Cycle, applying a manual cycle and soak to your schedules takes some work and configuration to implement.
## How can I use Smart Cycle, manual cycle and soak, or edit my selection?
You can make your cycle and soak selection during the schedule creation process. Want to edit cycle and soak or add Smart Cycle to a schedule?
1\. Select the "Schedules" tab
2\. Tap the schedule you would like to edit, then scroll down and tap "Cycle and soak."
3\. Tap the option you would like to apply to your schedule (Smart Cycle will automatically apply to your schedule, unless you make a different selection). Want to try manual cycle and soak instead? After making your selection, use the plus and minus buttons to adjust the length of "cycle" (minutes of active watering) and length of "soak" (minutes of delay between watering repeats).
## Smart Cycle FAQ
### How does Smart Cycle affect my watering times? Why do watering times sometimes seem longer?
With Smart Cycle activated, watering times may **seem** longer on the surface. But don't worry - **your schedules are not applying more water, just watering more efficiently**. Watering less frequently for longer is usually the best long-term thing to do for your lawn.
### How long can a zone's watering duration continue before it needs to get cycle-soaked?
The following table shows the relationship between soil type (precipitation intake rate) and slope. Notice that clay, which does not have a very high intake rate, is allowed much smaller surface accumulation than either loam (topsoil) or sand.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/fa662ac4baf1d13c12068b665cbf423a.png)
#### The Maximum Runtime allowable before runoff occurs will be calculated from the following formula:
Rt (max) = 60 (ASA)/(PR – IR), minutes
ASA = Allowable Surface Accumulation
PR = Precipitation Rate. The amount of irrigation water applied per unit of time.
IR = Soil intake rate
The following are the maximum allowable watering minutes without cycling for different types of soils, slopes, and nozzles.
Nozzle
In/hr
Soil
Slope
Max Runtime Minutes
Fixed Spray Head
1.5
Clay
Flat
8
Fixed Spray Head
1.5
Clay
Slight
6
Fixed Spray Head
1.5
Clay
Moderate
Fixed Spray Head
1.5
Clay
Steep
Fixed Spray Head
1.5
Silty Clay
Flat
10
Fixed Spray Head
1.5
Silty Clay
Slight
8
Fixed Spray Head
1.5
Silty Clay
Moderate
7
Fixed Spray Head
1.5
Silty Clay
Steep
Fixed Spray Head
1.5
Clay Loam
Flat
12
Fixed Spray Head
1.5
Clay Loam
Slight
10
Fixed Spray Head
1.5
Clay Loam
Moderate
8
Fixed Spray Head
1.5
Clay Loam
Steep
6
Fixed Spray Head
1.5
Loam
Flat
15
Fixed Spray Head
1.5
Loam
Slight
13
Fixed Spray Head
1.5
Loam
Moderate
10
Fixed Spray Head
1.5
Loam
Steep
8
Fixed Spray Head
1.5
Sandy Loam
Flat
18
Fixed Spray Head
1.5
Sandy Loam
Slight
15
Fixed Spray Head
1.5
Sandy Loam
Moderate
13
Fixed Spray Head
1.5
Sandy Loam
Steep
10
Fixed Spray Head
1.5
Loamy Sand
Flat
21
Fixed Spray Head
1.5
Loamy Sand
Slight
18
Fixed Spray Head
1.5
Loamy Sand
Moderate
15
Fixed Spray Head
1.5
Loamy Sand
Steep
13
Fixed Spray Head
1.5
Sand
Flat
26
Fixed Spray Head
1.5
Sand
Slight
23
Fixed Spray Head
1.5
Sand
Moderate
20
Fixed Spray Head
1.5
Sand
Steep
16
Rotor Head
Clay
Flat
13
Rotor Head
Clay
Slight
10
Rotor Head
Clay
Moderate
6
Rotor Head
Clay
Steep
6
Rotor Head
Silty Clay
Flat
16
Rotor Head
Silty Clay
Slight
13
Rotor Head
Silty Clay
Moderate
11
Rotor Head
Silty Clay
Steep
9
Rotor Head
Clay Loam
Flat
19
Rotor Head
Clay Loam
Slight
16
Rotor Head
Clay Loam
Moderate
13
Rotor Head
Clay Loam
Steep
11
Rotor Head
Loam
Flat
27
Rotor Head
Loam
Slight
23
Rotor Head
Loam
Moderate
19
Rotor Head
Loam
Steep
15
Rotor Head
Sandy Loam
Flat
33
Rotor Head
Sandy Loam
Slight
29
Rotor Head
Sandy Loam
Moderate
24
Rotor Head
Sandy Loam
Steep
20
Rotor Head
Loamy Sand
Flat
43
Rotor Head
Loamy Sand
Slight
36
Rotor Head
Loamy Sand
Moderate
31
Rotor Head
Loamy Sand
Steep
26
Rotor Head
Sand
Flat
60
Rotor Head
Sand
Slight
52
Rotor Head
Sand
Moderate
45
Rotor Head
Sand
Steep
37
Rotary Nozzle
0.7
Clay
Flat
20
Rotary Nozzle
0.7
Clay
Slight
15
Rotary Nozzle
0.7
Clay
Moderate
10
Rotary Nozzle
0.7
Clay
Steep
10
Rotary Nozzle
0.7
Silty Clay
Flat
25
Rotary Nozzle
0.7
Silty Clay
Slight
20
Rotary Nozzle
0.7
Silty Clay
Moderate
17
Rotary Nozzle
0.7
Silty Clay
Steep
14
Rotary Nozzle
0.7
Clay Loam
Flat
31
Rotary Nozzle
0.7
Clay Loam
Slight
26
Rotary Nozzle
0.7
Clay Loam
Moderate
21
Rotary Nozzle
0.7
Clay Loam
Steep
18
Rotary Nozzle
0.7
Loam
Flat
51
Rotary Nozzle
0.7
Loam
Slight
42
Rotary Nozzle
0.7
Loam
Moderate
36
Rotary Nozzle
0.7
Loam
Steep
29
Rotary Nozzle
0.7
Sandy Loam
Flat
66
Rotary Nozzle
0.7
Sandy Loam
Slight
58
Rotary Nozzle
0.7
Sandy Loam
Moderate
48
Rotary Nozzle
0.7
Sandy Loam
Steep
40
Rotary Nozzle
0.7
Loamy Sand
Flat
108
Rotary Nozzle
0.7
Loamy Sand
Slight
90
Rotary Nozzle
0.7
Loamy Sand
Moderate
78
Rotary Nozzle
0.7
Loamy Sand
Steep
66
Rotary Nozzle
0.7
Sand
Flat
240
Rotary Nozzle
0.7
Sand
Slight
210
Rotary Nozzle
0.7
Sand
Moderate
180
Rotary Nozzle
0.7
Sand
Steep
150
K-Rain Rotary
0.54
Clay
Flat
27
K-Rain Rotary
0.54
Clay
Slight
20
K-Rain Rotary
0.54
Clay
Moderate
13
K-Rain Rotary
0.54
Clay
Steep
13
K-Rain Rotary
0.54
Silty Clay
Flat
35
K-Rain Rotary
0.54
Silty Clay
Slight
29
K-Rain Rotary
0.54
Silty Clay
Moderate
24
K-Rain Rotary
0.54
Silty Clay
Steep
20
K-Rain Rotary
0.54
Clay Loam
Flat
45
K-Rain Rotary
0.54
Clay Loam
Slight
38
K-Rain Rotary
0.54
Clay Loam
Moderate
31
K-Rain Rotary
0.54
Clay Loam
Steep
26
K-Rain Rotary
0.54
Loam
Flat
94
K-Rain Rotary
0.54
Loam
Slight
78
K-Rain Rotary
0.54
Loam
Moderate
66
K-Rain Rotary
0.54
Loam
Steep
53
K-Rain Rotary
0.54
Sandy Loam
Flat
141
K-Rain Rotary
0.54
Sandy Loam
Slight
124
K-Rain Rotary
0.54
Sandy Loam
Moderate
102
K-Rain Rotary
0.54
Sandy Loam
Steep
85
K-Rain Rotary
0.54
Loamy Sand
Flat
539
K-Rain Rotary
0.54
Loamy Sand
Slight
450
K-Rain Rotary
0.54
Loamy Sand
Moderate
390
K-Rain Rotary
0.54
Loamy Sand
Steep
330
K-Rain Rotary
0.54
Sand
Flat
No Maximum
K-Rain Rotary
0.54
Sand
Slight
No Maximum
K-Rain Rotary
0.54
Sand
Moderate
No Maximum
K-Rain Rotary
0.54
Sand
Steep
No Maximum
Mister
Clay
Flat
6
Mister
Clay
Slight
Mister
Clay
Moderate
Mister
Clay
Steep
Mister
Silty Clay
Flat
7
Mister
Silty Clay
Slight
6
Mister
Silty Clay
Moderate
Mister
Silty Clay
Steep
Mister
Clay Loam
Flat
8
Mister
Clay Loam
Slight
7
Mister
Clay Loam
Moderate
6
Mister
Clay Loam
Steep
Mister
Loam
Flat
10
Mister
Loam
Slight
9
Mister
Loam
Moderate
7
Mister
Loam
Steep
6
Mister
Sandy Loam
Flat
12
Mister
Sandy Loam
Slight
10
Mister
Sandy Loam
Moderate
9
Mister
Sandy Loam
Steep
7
Mister
Loamy Sand
Flat
14
Mister
Loamy Sand
Slight
12
Mister
Loamy Sand
Moderate
10
Mister
Loamy Sand
Steep
8
Mister
Sand
Flat
17
Mister
Sand
Slight
15
Mister
Sand
Moderate
12
Mister
Sand
Steep
10
Emitter
0.5
Clay
Flat
30
Emitter
0.5
Clay
Slight
22
Emitter
0.5
Clay
Moderate
15
Emitter
0.5
Clay
Steep
15
Emitter
0.5
Silty Clay
Flat
39
Emitter
0.5
Silty Clay
Slight
32
Emitter
0.5
Silty Clay
Moderate
27
Emitter
0.5
Silty Clay
Steep
22
Emitter
0.5
Clay Loam
Flat
52
Emitter
0.5
Clay Loam
Slight
44
Emitter
0.5
Clay Loam
Moderate
36
Emitter
0.5
Clay Loam
Steep
30
Emitter
0.5
Loam
Flat
120
Emitter
0.5
Loam
Slight
100
Emitter
0.5
Loam
Moderate
84
Emitter
0.5
Loam
Steep
68
Emitter
0.5
Sandy Loam
Flat
198
Emitter
0.5
Sandy Loam
Slight
174
Emitter
0.5
Sandy Loam
Moderate
144
Emitter
0.5
Sandy Loam
Steep
120
Emitter
0.5
Loamy Sand
Flat
No Maximum
Emitter
0.5
Loamy Sand
Slight
No Maximum
Emitter
0.5
Loamy Sand
Moderate
No Maximum
Emitter
0.5
Loamy Sand
Steep
No Maximum
Emitter
0.5
Sand
Flat
No Maximum
Emitter
0.5
Sand
Slight
No Maximum
Emitter
0.5
Sand
Moderate
No Maximum
Emitter
0.5
Sand
Steep
No Maximum
Drip Line
0.5
Clay
Flat
30
Drip Line
0.5
Clay
Slight
22
Drip Line
0.5
Clay
Moderate
15
Drip Line
0.5
Clay
Steep
15
Drip Line
0.5
Silty Clay
Flat
39
Drip Line
0.5
Silty Clay
Slight
32
Drip Line
0.5
Silty Clay
Moderate
27
Drip Line
0.5
Silty Clay
Steep
22
Drip Line
0.5
Clay Loam
Flat
52
Drip Line
0.5
Clay Loam
Slight
44
Drip Line
0.5
Clay Loam
Moderate
36
Drip Line
0.5
Clay Loam
Steep
30
Drip Line
0.5
Loam
Flat
120
Drip Line
0.5
Loam
Slight
100
Drip Line
0.5
Loam
Moderate
84
Drip Line
0.5
Loam
Steep
68
Drip Line
0.5
Sandy Loam
Flat
198
Drip Line
0.5
Sandy Loam
Slight
174
Drip Line
0.5
Sandy Loam
Moderate
144
Drip Line
0.5
Sandy Loam
Steep
120
Drip Line
0.5
Loamy Sand
Flat
No Maximum
Drip Line
0.5
Loamy Sand
Slight
No Maximum
Drip Line
0.5
Loamy Sand
Moderate
No Maximum
Drip Line
0.5
Loamy Sand
Steep
No Maximum
Drip Line
0.5
Sand
Flat
No Maximum
Drip Line
0.5
Sand
Slight
No Maximum
Drip Line
0.5
Sand
Moderate
No Maximum
Drip Line
0.5
Sand
Steep
No Maximum
Bubbler
Clay
Flat
13
Bubbler
Clay
Slight
10
Bubbler
Clay
Moderate
6
Bubbler
Clay
Steep
6
Bubbler
Silty Clay
Flat
16
Bubbler
Silty Clay
Slight
13
Bubbler
Silty Clay
Moderate
11
Bubbler
Silty Clay
Steep
9
Bubbler
Clay Loam
Flat
19
Bubbler
Clay Loam
Slight
16
Bubbler
Clay Loam
Moderate
13
Bubbler
Clay Loam
Steep
11
Bubbler
Loam
Flat
27
Bubbler
Loam
Slight
23
Bubbler
Loam
Moderate
19
Bubbler
Loam
Steep
15
Bubbler
Sandy Loam
Flat
33
Bubbler
Sandy Loam
Slight
29
Bubbler
Sandy Loam
Moderate
24
Bubbler
Sandy Loam
Steep
20
Bubbler
Loamy Sand
Flat
43
Bubbler
Loamy Sand
Slight
36
Bubbler
Loamy Sand
Moderate
31
Bubbler
Loamy Sand
Steep
26
Bubbler
Sand
Flat
60
Bubbler
Sand
Slight
52
Bubbler
Sand
Moderate
45
Bubbler
Sand
Steep
37
### How does Smart Cycle REALLY work?
When running a watering schedule with Smart Cycle turned on, Rachio software divides the total watering time for each zone into a number of cycles. For each cycle, a zone is watered for a period of time short enough so that the water will not immediately runoff. The next zone is then watered for its period of time, etc., until all of the zones have had their "cycle". During this process, it's important that the soil in each zone gets enough time to absorb the water. Specifically, Rachio guarantees that each zone will get at least 30 minutes between the end of one cycle and the beginning of the next.
Let's look at an example: imagine that we had 4 zones, all grass with normal topsoil, all with popup sprinklers. The recommended watering time for each zone for this time of year is 30 minutes twice a week (must be August!), starting at 5 AM. With Smart Cycle, the watering schedule would look something like this:
*   5:00 - water zone 1 for 15 minutes - the maximum recommended watering cycle time for popup sprinklers on topsoil is about 22 minutes (see below). Since our watering time of 30 minutes exceeds that, Rachio will break it up into 2 even cycles of 15 minutes
*   5:15 - water zone 2 for 15 minutes - same as Zone 1
*   5:30 - water zone 3 for 15 minutes
*   5:45 - water zone 4 for 15 minutes
*   6:00 - water zone 1 for 15 minutes - it's been at least 30 minutes since zone 1 finished its first cycle, so it's OK to water it again.
*   And so on, for zones 2-4
But what if one of the zones was different - say, a tree that needs only 20 minutes of water in zone 4? The number of cycles is different for each zone, so zone 4 will only water once for 20 minutes in the first cycle, the second cycle will only have zones 1-3.
What are Cycle Times / Wait Times in Smart Cycle?
Sometimes, it's not possible to schedule a cycle such that the watering times of all of the other zones gives us our 30 minutes between cycles. If that's the case, the controller will "cycle" or wait, for as many minutes as it takes to make sure that all zones get the soaking time they need before getting more water.
Here's an example: Imagine a watering time with 4 zones that need to be watered for 30 minutes each, all with grass, popup sprinklers, and clay soil. The recommended maximum watering time per cycle for this situation is only 5 minutes (see below), so the controller will break the schedule up into 6 cycles of 5 minutes apiece. The schedule for this would be:
*   5:00 - 5:20: Water zones 1- 4 for 5 minutes each
*   5:20: Cycling phase 1 of 6 begins - zone 1 finished watering at 5:05, and it's 5:20 now, so the water hasn't had enough time to soak in. To solve this, Rachio will simply wait for 15 minutes, to give zone 1 enough time (cycling takes 30 minutes per zone)
*   5:35: 5:55 - zone 1 has had 30 minutes to cycle and let the water soak in. Watering resumes, followed by the rest of the zones, for another 5 minutes
*   5:55: Cycling phase 2 of 6. Wait for 15 minutes, etc., until all zones have had 30 minutes to soak.
*   8:30: We're done!
## Rachio Smart Hose Timer
### Smart Soak
Available under the **More Options** dropdown menu, **Smart Soak** splits up schedule runs to allow water time to soak into the ground. It improves watering in clay-rich soils and/or long schedule runs.
![](https://cdn.kustomerhostedcontent.com/media/5f775c7b7cad407e578daa84/9b65b3ca91bc1c92fc512d8a57f4c380.png)
Smart Soak splits the total watering time for any individual cycle into two equal parts. At the start, it waters for the first half of the total duration. Then, it pauses to let the water soak in for at least the same duration as the first watering session, potentially extending this soak period if multiple runs or valves are active in the schedule. After the soak, it resumes watering for the second half of the total duration to complete the cycle.
*   When using Smart Soak, each valve will soak for at least 50% of the runtime of the longest-running valve included in that schedule.
*   When a schedule includes multiple valves, the system enhances efficiency by cycling between them to reduce total runtime, operating one valve while others soak.
*   If you’re using the “Open valves at the same time” feature in your schedule, you can expect to see even more soak time; as your valves will not resume their watering until the longest-running valve included in that schedule has completed its soaking.
