What does Light Three mean? (Generation 2)
Light Three (Connecting to the Rachio Cloud)
This light will begin blinking as the controller attempts to connect to Rachio's servers. Once connected, it will turn solid. If it fails to connect, it will continue blinking. Usually this indicates a security or firewall setting is getting in the way. An easy fix is to create a guest network with default settings & reattempt to connect your controller to WiFi.
Light Three Troubleshooting
General
  • Advanced security and firewall settings can stop the controller from being able to communicate outside of your local network.
  • Double check to ensure your router's firmware is up to date.
  • Run a WiFi Network Diagnostic test. See article: Is my WiFi Network compatible?
iOS (Apple)
  • See above. A solid Light Two indicates the controller connected to WiFi properly.
Android
  • If hung up on Connecting to Device, go into your phone's WiFi settings and ensure you are connected to the desired 2.4Ghz/dual band network. If you change networks, you will need to restart the setup process.
