What does Light Two mean? (Generation 2)
Light Two = Connecting to Wi-Fi
[Gen2 Light Three]
This light will begin blinking as the controller tries to connect to your Wi-Fi network. Once connected to your Wi-Fi network, the light will turn solid.
Light Two Troubleshooting
General
  • Turn off cellular dataWiFi Assist features on both iOS and Android devices can interfere with your local WiFi networks by switching to the strongest network available inadvertently.
  • Check your network. Ensure you're connected to a network broadcasting at 2.4 GHz. -- If in doubt, create a guest network using default router settings.
    WiFi requirements are:
    • 802.11b/g/n (2.4 GHz) -- dual band (2.4 / 5 GHz) supported, but "blended" networks are NOT recommended.
    • WPA2 Personal (WPS and WPA2 Enterprise are NOT supported)
iOS (Apple)
  • Connect to the desired WiFi network you wish to add the controller to via your phone's WiFi settings.
  • Apple saves your WiFi network password(s) and will share it with the Rachio app.
Android
  • Connect to the desired WiFi network you wish to add the controller to, via your phone's WiFi settings, to ensure you have the correct password.
  • Unlike Apple, Android devices DO NOT save your WiFi network password(s) to share automagically with the Rachio app.
