How do I activate my controller? (Generation 2)
Controller activation steps & tips
IN THIS ARTICLE
  • WiFi Setup Video
  • Step by Step Instructions
  • WiFi Setup Tips
  • WiFi Reset Steps
  • WiFi Setup Video
    WiFi setup is easy! Connect to a 2.4 or dual band network. Watch this video for tips & tricks:
    Double check the lights on your controller
    Your Gen2 Rachio is ready for Wi-Fi setup when Light One is solid and Light Two is blinking.
    Connect your smartphone or tablet to WiFi
    Your mobile device needs to be connected to the network you'll be adding the controller to.
    Note: Use a 2.4 or DUAL band network to connect your Rachio to WiFi. Rachio controller's will NOT connect to a 5ghz ONLY network. If in doubt, create a guest network.
    We also recommend putting your phone into airplane mode or disabling Wi-Fi assist (iOS) or Smart Network Switch (Android) while connecting the controller to WiFi to avoid any interference with your data plan; see WiFi assist for details.
    Download the Rachio app
    Rachio's app is free on the Apple App store or Google Play store.
    Open the Rachio app and register for an account
    This requires name, email address, username and password.
    Add Device via Rachio App
    The Rachio app prompts you to Add a Device > tap to continue. Select the generation of controller you have (if Gen 1, please refer to this videoAdd Device / Device Select
    6
    Find/Select your Controller
    Rachio app will attempt to find your controller. If it cannot find your controller, please refer to this  support article.
    Select your controller from the list of available devices.
    Note: If you’re installing more than one controller, you can verify the controller you’re installing by matching the available device ID with the last six digits of the MAC number. The MAC number is printed on the label found on the front of the controller.
    Add Device / Available Devices
    7
    Select the Desired Network
    Remember the chosen network must be the same connection your mobile device is on and must be 2.4 ghz or dual band (2.4 ghz / 5 ghz). Once selected, the Rachio app will attempt to connect your controller to Wi-Fi.
    8
    Verify Serial Number
    The Rachio app will ask you to verify the serial number of the device. It is a 7 digit number preceded by a 2 letter code. The serial number is printed on the label found on the front of the controller. Once entered, the Rachio app will attempt to activate your controller. [nufan]
    9
    If successful, the Rachio app will display "Device Activated" and allow you to continue to setup. For setup instructions, please refer to  this video. [nufan]
    WiFi Setup Tips
    Recommended tips by operating system:
    iOS (Apple)
    • Connect to the WiFi network you plan on adding the controller to (2.4 ghz optimized) and disable your cellular data before attempting WiFi setup (see Wi-Fi assist (iOS) for details).
    • Do not attempt to connect your controller via WiFi in your phone's settings. The controller has to be connected using the Rachio app.
    Android
    • Connect to the WiFi network you plan on adding the controller to (2.4 ghz optimized) and disable your cellular data before attempting WiFi setup (see Smart Network Switch (Android) for details).
    • WiFi setup on Android requires the correct input of both your WiFi network password and controller's serial number. If either are incorrect, the process will fail.
    Controller Light Codes
    • Once WiFi Setup is complete, all four lights of the Rachio logo should be lit solid. If you cannot connect, please review the light code you are seeing and attempt the troubleshooting recommended.
    WiFi Reset Steps
    If your WiFi network credentials have changed (Name/SSID and/or password), we recommend you perform a WiFi Reset and NOT a Factory Reset. A WiFi Reset will clear the controller's network settings, but not the yard or schedule settings.
    For a Step-by-Step guide on how to reset wifi on your Rachio Generation 2 controller, please see: How do I update wifi on my controller? (Generation 2)
