How Rachio works with Nest
Nest Integration
IN THIS ARTICLE
Rachio helps protect your neighbors by mitigating fire spread.
  • Rachio will automatically begin cycling through your sprinkler zones if your Nest Protect detects smoke.
  • Rachio saturates your outdoors and helps mitigate fire spread to your community, creating a defensible space around your home.
How does it work, exactly?
We're glad you asked! ;-)
If the Nest Protect reaches it's highest level of alert (emergency - level 3), Rachio will automatically run through each enabled zone for 5 minutes, two times. For example, if you have 8 enabled zones, the sprinklers will run for 80 minutes total. There is up to a 60 second latency between the time Nest Protect reaches emergency and the Rachio starts cycling.
Once these cycles start, they are unaffected by the Nest device, meaning you sprinklers will continue to run to completion, regardless of the Nest Protect status. If you want to stop your zones while they're running you can do so by logging into your Rachio app and clicking on the Stop button on your apps Activity Feed tab.
For a step-by-step guide on how to integrate your Nest account with Rachio, continue reading...
Step by Step Instructions
Login
  • First you will need to login to your account using our web interface.
  • 2
    Add Nest
  • Once logged in click on the "Add" button in the Integrations card and select Nest.
  • 3
    Continue to Nest
  • The next page will be a disclaimer explaining how the integration will work. After clicking continue you will need to login to your Nest account if you are not already logged in.
  • 4
    Select Home(s)
  • Once you have logged in you will be brought back to the Rachio Web App page and will able to choose the Home that you wish to use for this integration. If you have more than one home, you can add all of them that have a Rachio controller at the same location. Please note that it may take a minute or 2 for this pop up window to appear showing the Homes you can connect with.
  • 5
    Confirm Success
  • Once a Home is selected you will see it show up on your Integrations card meaning it has successfully connected.
  • 6
    Disconnect?
  • If at any point you feel the need to disconnect your Rachio from your Nest device simply click on the "Revoke" button below the Home you would like to disconnect from and you will receive a successful disconnection notice in your Device Updates card.
  • Go to Top ^
    Fun Nest Cam* Integration
    Nest and Rachio can work together in other ways too! Utilizing the If This Then That (IFTTT) app, you can create recipes that allow Nest devices and the Rachio to interact with one another. For more details on IFTTT and recipes see  this article. Our customers have come up with some pretty creative recipes with this integration like turning on the sprinklers whenever the Nest Cam detects an animal for example.
    Finally, if you have any suggestions on how else our integration with Nest could work  submit it as a feature request and we'll be sure to see what we can do!
    *formerly Drop Cam
