Is my router supported?
Rachio and Incompatible Hardware
Although Rachio is compatible with most networking equipment, some network devices are incompatible.
Usually when networking hardware does not work with Rachio, it’s because it lacks support for the network protocols that Rachio uses to operate.
The equipment below is incompatible with Rachio. Be aware that the majority of this list is made up of older networking equipment, but may still exist as part of a home network. We try to keep this list up-to-date, but it is only indicative. If you have a question about your router or other network equipment, please see the WiFi Troubleshooting section at the end of this article.
Network hardware that is incompatible, but a workaround or fix is available
NOTE: Rachio controllers support both dual band* and single band routers.
In general, as long as your router has a steady 2.4 GHz connection on a secured (WPA/WPA2) network, it will work.
    Cisco RE1000 - Router Defaults to WEP encryption
    D-LinkDIR-300 - Multiple setup attempts may be required by users.
    MotorolaSBG6580 - Defaults to WEP encryption
    Western Digital AC1300-J2F - Change Channel Width to 20Mhz
    Netgear Nighthawk N7000 - Known issue when 2.4Ghz and 5Ghz share the same name
    Linksys E4200 - Known issue when 2.54Ghz and 5Ghz share the same name
    EdgeMax routers -- Security settings defaulted to WEP
To change your router settings, please reference SetupRouter.com. (routers are listed alphabetically).
WiFi Extenders FAQ
  • Extenders will work with the Rachio under some restrictions.
  • If the Rachio is in a central location that can connect to both the extender and the main access point, the Rachio may bounce between both access points.
  • If you see frequent disconnects you will want to make the SSIDs have different names and passwords
To assist our team in better helping you with your Wi-Fi issue, we’d ask that you complete a Wi-Fi diagnostic before you contact our support team in help solve your issue quickly. To complete a WiFi diagnostic, please  follow the steps in this support article.
